Community
cancel
Showing results for
Search instead for
Did you mean:
YaLun_T_Intel
technical query for Intel Aero
hi, can i check whether the motors and ESCs that connected to Intel Aero board, compatible to connect those ESCs with servo cables to other controller system such as Navio2 and Naza V2? i have naza v2 and navio 2 but i do not know whether i could connect the motors and ESCs up to one of the boards if i wanted to try.
Tags (1)
Community Manager
Hello yalun89,
Thanks for reaching out!
Do you know which interface is used on your ESCs to communicate? If that interface is compatible with any of Aero's interfaces, then you should indeed be able to use your ESCs with Aero. I suggest you to check both the Aero (you can check them in https://software.intel.com/en-us/aero/dev-kit) and your ESCs interfaces to verify if they are compatible.
I hope this helps.
-Peter.
Community Manager
Thank you for sending us the image of your ESC.
I'm not familiar with this device, is it possible for you to share the technical specifications of your specific ESCs? Or can you share a link to this information?
With this information we might be able to provide you a more accurate answer.
I'll be waiting for your response.
-Peter.
YaLun_T_Intel
may i know the aero board has the servo connector head for ESCs to be connected or plugged?
the ESC i have is with servo head connector but plugged into 3 pin of the flight controller for ESCs
http://www.flyingtech.co.uk/sites/default/files/Product_images/BlHeli%2040A.jpg http://www.flyingtech.co.uk/sites/default/files/Product_images/BlHeli%2040A.jpg
naza flight controller
https://sites.google.com/site/marcobotprojects/_/rsrc/1443839834968/my-projects/building-a-f450-flam... https://sites.google.com/site/marcobotprojects/_/rsrc/1443839834968/my-projects/building-a-f450-flam...
but for aero board, i dont know whether it can support the PWM pulse signal to control the ESCs.
Community Manager
Let me check more information about this. If I find something useful for you, I will make sure to post it here.
-Peter.
Community Manager
Hello yalun89,
In order to use ESCs with Aero you need to connect a flight controller to the board. Once the flight controller is connected to the Aero Compute board, the flight controller will be responsible to control the motors/ESC.
Please take a look at this guide on how to connect a flight controller:
https://communities.intel.com/thread/108215 https://communities.intel.com/thread/108215
I hope this helps.
-Peter.
