Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
774 Discussions
to establish mavlink-router or mavros connection between drone and computer
UGoya
Hello
I want to run my launch file, which I am not able to run on the drone due to connection problem, I am attaching my launch file so that it will be easy to check the fcu_url in the launch fileScreenshot from 2019-03-14 11-53-19.png
I am also attaching my mavlink-router configuration file.
I am also attaching my device port informationScreenshot from 2019-03-14 11-57-07.png
Please help to have successful connection.
Thanks and Regards
Utkarsh
Alexandra_C_Intel
Hi UGoya,
Thank you for your interest in the Intel Aero drone.
Could you please tell me the output of aero-get-version.py?
Alexandra
UGoya
Hello Alexandra
The output of the command:
Alexandra_C_Intel
Hi UGoya, Please try updating the software and components. https://github.com/intel-aero/meta-intel-aero/wiki/02-Initial-setup#flashing It's possible the baud rate is different as there were changes throughout the software releases. Regards, Alexandra
UGoya
Hi Alexandra
I think after updating the software and components and adding something in the configuration file of mavlink-router, I have successfully launch my file and my system is now working fine.
Thanks for the support.
Utkarsh
