Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
774 Discussions
use opencv to access the bottom camera error
栩张
Hi chillaxintel_corp
Sorry to disturb you.
I just want to test a code of visual odometry algorithm by using the bottom camera(use opencv cap class).
but when I run the rode there will occur an error like this:
highgui error:libv4l unable to ioctl s_fmt
here is the code I wrote:
void BenchmarkNode::runFromFolder()
cv::VideoCapture cap(1); // open the default camera
if (!cap.isOpened()) // check if we succeeded
return ;
int img_id = 0;
for (;;) {
cv::Mat image;
cap.read(image); // get a new frame from camera
assert(!image.empty());
img_id++;
cv::imshow("origin_image", image);
if (cv::waitKey(1) >= 0) break;
if(img_id < 100) continue;
cv::cvtColor(image,image,CV_BGR2GRAY);
cv::Mat unimg;
cam_pinhole_->undistortImage(image,unimg);
vo_->addImage(unimg, 0.01*img_id);
vo_->addImage(image, 0.01*img_id);
// display tracking quality
if(vo_->lastFrame() != NULL)
std::cout << "Frame-Id: " << vo_->lastFrame()->id_ << " \t"
<< "# Features: " << vo_->lastNumObservations() << " \n";
//<< "Proc. Time: " << vo_->lastProcessingTime()*1000 << "ms \n";
std::cout<<"Frame pose: "<< vo_->lastFrame()->T_f_w_ <<std::endl;
cap.release();
return;
Do anyone know how to use the cv::VideoCapture cap to access the bottom?
Community Manager
Hello tuantuan91,
Thank you for your interest in the Intel Aero RTF drone.
We have received your request and we are currently investigating.
I will get back to you as soon as possible.
Eliza
栩张
Hi Eliza
Thanks for your reply.
In fact my question is could I use opencv 2.4.13 to capture video stream from the bottom camera(/dev/video2) for my code?
I think this explanation is easier for understanding.
栩张
Hi Eliza
Sorry to disturb you again.
I just modified my code in this line:
//cv::VideoCapture cap(0);
cv::VideoCapture cap("/dev/video2");
I got the Error in Opnecv:
GStreamer:unable to start pipeline.
Community Manager
Hello tuantuan91,
Thank you for your patience.
In order for us to be able to understand the issue better, please attach the .cpp file.
The bottom camera should be "rtsp://AERO_IP_ON_YOUR_NETWORK:8554/bottom", can you please try that and let me know the outcome?
Thank you in advance,
Eliza
栩张
Hi Eliza
I think your answer is about using wifi-signal to get video stream on QGC.
But for my question I want to know how to use Opencv(C++) to access the bottom camera's video stream on ubuntu.
I'm doing some research in visual odometry.
These are different problem.
栩张
Hi Eliza
Here is the cpp.file I wrote.
// This file is part of SVO - Semi-direct Visual Odometry.
// Copyright (C) 2014 Christian Forster
// (Robotics and Perception Group, University of Zurich, Switzerland).
// SVO is free software: you can redistribute it and/or modify it under the
// terms of the GNU General Public License as published by the Free Software
// Foundation, either version 3 of the License, or any later version.
// SVO is distributed in the hope that it will be useful, but WITHOUT ANY
// WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
// FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details.
// You should have received a copy of the GNU General Public License
// along with this program. If not, see <</span> http://www.gnu.org/licenses/>.
# include
# include
# include
# include
# include
# include
# include
# include
# include
# include
# include
# include
# include
class BenchmarkNode
svo::AbstractCamera* cam_;
svo::PinholeCamera* cam_pinhole_;
svo::FrameHandlerMono* vo_;
SLAM_VIEWER::Viewer* viewer_;
std::thread * viewer_thread_;
public:
BenchmarkNode();
~BenchmarkNode();
void runFromFolder();
BenchmarkNode::BenchmarkNode()
cam_pinhole_ = new svo::PinholeCamera(640,480,502.961104,503.651566, 284.978460, 247.527333,
-0.378740,0.133422, -0.001505, -0.001445);
cam_ = new svo::PinholeCamera(640,480,407.763641, 453.693298, 267.111836,247.958895);
cam_ = new svo::PinholeCamera(640,480,482.62565,480.83271, 323.96419, 261.20336, -0.031563,0.165711,0.001507,-0.00083,-0.18942);
vo_ = new svo::FrameHandlerMono(cam_);
vo_->start();
viewer_ = new SLAM_VIEWER::Viewer(vo_);
viewer_thread_ = new std::thread(&SLAM_VIEWER::Viewer::run,viewer_);
viewer_thread_->detach();
BenchmarkNode::~BenchmarkNode()
delete vo_;
delete cam_;
delete cam_pinhole_;
delete viewer_;
delete viewer_thread_;
//# define TXTREAD
return ;
int img_id = 0;
for (;;) {
cv::Mat image;
img_id++;
cv::Mat unimg;
cap.release();
return;
int main(int argc, char** argv)
BenchmarkNode benchmark;
benchmark.runFromFolder();
printf("BenchmarkNode finished.\n");
return 0;
Community Manager
Hello tuantuan91,
The camera from Intel Aero Ready to Fly drone needs to be accessed a certain way.
You can check how to open the camera using V4L2 APIs and then try to use other libraries that will call V4L2 APIs for you. Bellow is the link for a source code that will show you how to to access the camera.
https://github.com/intel-aero/sample-apps/blob/master/capturev4l2/capture.cpp https://github.com/intel-aero/sample-apps/blob/master/capturev4l2/capture.cpp
Please let me know in case you have any other questions.
Best regards!
Eliza
栩张
Hi Eliza
Thanks for your help.
