Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
775 Discussions
wget -qO - https://download.01.org/aero/deb/intel-aero-deb.key | sudo apt-key add - This command is not working.
UGoya
I am using Intel Aero RTF drone.
I have successfully installed the Ubuntu on it, but when I to execute the command
It is just processing and not giving any output.
Please help
Utkarsh
Eliza_D_Intel
Hello Utkarsh,
It seems that the site was down, but now it's up and running.
Could you please try again the original command?
Thank you and best regards,
Eliza
Eliza_D_Intel
Hello Utkarsh, Indeed, I have received the same error when using it. Can you please check if with this line you have better luck? wget https://download.01.org/aero/deb/intel-aero-deb.key | sudo apt-key add - If it's not working, is it possible to skip this line and let us know if the other dependencies will get installed without this key? Thank you and best regards, Eliza
UGoya
Hello Eliza
I tried this above command also, but this also not working.
So I will skip this line and continue to install all the dependencies, if there is any problem i will let you know.
I also attach the screenshot of the output that I got after executing the command given by you.
But, Thanks for the response
Utkarsh
UGoya
Hello Eliza
I have tried this command
sudo apt-get -y install aero-system
But this has given the following error:
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package aero-system
I think this is because of not executing the command which I skip.
So can you please check into this problem and can provide me the solution.
Thanks and Regards
Utkarsh
Eliza_D_Intel
Hello Utkarsh, Thank you! You are right. Let me look into this and I will reach you back as soon as possible. Thank you and best regards, Eliza
Eliza_D_Intel
Hello Utkarsh,
Eliza
UGoya
Hello Eliza
Thank You, command successfully worked for me.
And I was able to install all the dependencies.
Utkarsh
