Hi .
I'm using cameras in Intel Aero Vision kit for image processing of UAV
When I run the sample program what Intel offers, https://github.com/intel-aero/sample-apps GitHub - intel-aero/sample-apps: This repository will contain source code for sample applications
it was successful. so it got the monochrome image from ov7251.
I have planned using this camera and its image but it only works when ov8858 connected together with ov7521.
I don't know why
Here is command message I put,
C=10 INPUT=1 MODE=PREVIEW capture_example --userp -d /dev/video0
and an error message is
VIDIOC_S_FMT error 22, Invalid argument
Anyone know that a reason and how to fix?
Hi greiny,
Thanks for your interest in the Intel® Aero™ Platform for UAVs.
You are right, it is strange that the sample code only works when connecting both cameras. Please let us investigate this issue, we will contact you back as soon as we have some useful information.
Have a nice day!
-Jose P.
Hi greiny,
Just wanted to let you know that we are attempting to replicate your issue. As soon as an update develops I will contact you back.
Have a nice day!
-Jose P.
Hi greiny,
Thanks for your patience.
I was able to reproduce your issue by following these steps:
1. Update BIOS and image (1.3.1 version) of the Aero compute board. Also flashed the FPGA as well.
2. Once everything is setup, I copied the files with a flash memory under /home/sample-apps.
3. Compile the samples using this commands:
gcc spidev-app/spi_xfer.c -o spi_xfer
g++ -I${V} -c -o ${V}/atomisp_obj.o ${V}/atomisp_obj.cpp ${CFLAGS} ${LIBS}
g++ -I${V} -c -o ${V}/v4l2_obj.o ${V}/v4l2_obj.cpp ${CFLAGS} ${LIBS}
g++ -I${V} -c -o ${V}/capture.o ${V}/capture.cpp ${CFLAGS} ${LIBS}
g++ -pthread -o ${V}/capture_example ${V}/capture.o ${V}/v4l2_obj.o ${V}/atomisp_obj.o -I${V}
The variables used have to be defined first as follow:
export V="/home/sample-apps/capturev4l2"
export LIBS="-lstdc++ -lstlport"
export CFLAGS="-g -std=c++11 -Wall -DSTDC99 -D_REENTRANT -DATOMISP_CSS2 -DATOMISP_CSS2 -DATOMISP_CSS21"
4. Finally, I run the sample code and took the pictures with the VGA camera with the following command:
C=10 INPUT=1 MODE=PREVIEW ./home/sample-apps/capturev4l2/capture_example --userp -d /dev/video0
And with the RGB I used the following command:
C=10 INPUT=0 MODE=PREVIEW capture_example --userp -d /dev/video0
Unfortunately, I got the same error when disconnected the VGA camera. I think that this not an issue, but instead they are meant to be used like this, for example, if you want to develop a optic flow algorithm you will need both cameras in order to stabilize your Drone. Still, please let me investigate more in order to give you a correct answer.
-Jose P.
Hi Jose.
Thank you for your investigation.
I did same process with you did.
and I couldn't understand why you think that this not an issue.because I want to use VGA camera only but it is not possible now.
Would you give me another solution for this?
Regards.
Greiny
Hi greiny,
Yes, I understand your situation, we are investigating to see the reason of why this happens. As soon as I have an update I will be contacting you back.
Have a nice weekend!
-Jose P.
