Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
wifi stopped working
Community Manager
I updated the Aero linux distro to 1.6.1 and reinstalled Ububntu, according to:
https://github.com/intel-aero/meta-intel-aero/wiki/90-(References)-OS-user-Installation 90 (References) OS user Installation · intel-aero/meta-intel-aero Wiki · GitHub
Please also see pic attached.
After that the wifi in Ubuntu stopped working (in Yocto it's ok).
Please advise.
Thank you, Yoni.
DVrta
Hi Yoni,
do you have a stable WiFi connection on Yocto when the drone is AP ?
Because we also installed 1.6.1 on our board and we already have problems on Yocto, we connect with laptop to the drone but then it disconnects in a min or two and then connects again and disconnects.
BR.
MWnuk
The Ubuntu distro doesn't come standard with the driver for the intel 8260 wireless adapter installed on the aero. You'll need to download iwlwifi-8000-27 or iwlwifi-8000-31. Transfer it to the aero via usb then sudo mv it to the ~/lib/firmware directory. Then reboot and you should be good to go
Community Manager
Hi Yoni,
Please try not to select Wi-Fi when installing Ubuntu.
Try leaving the default settings when installing Ubuntu and let me know if that fixes your issue.
Alexandra
Community Manager
Hi Alexandra,
I installed the driver from the following link in the /lib/firmware directory
https://github.com/wkennington/linux-firmware/blob/master/iwlwifi-8000C-31.ucode linux-firmware/iwlwifi-8000C-31.ucode at master · wkennington/linux-firmware · GitHub
Now it's ok.
Thank you, Yoni.
