Intel® Arc™ Discrete Graphics
3686 Discussions
Alphacam & Rhino Problem
OnurKARABULUT
I recently built three new PCs for design purposes, choosing the Core Ultra 5 245KF and Intel Arc A750. However, the A750 has been a major disappointment for me. When I installed an older GTX 1050 on the system, I experienced very smooth performance, but with the A750, the performance is significantly worse. Can Intel optimize this card for software like Alphacam, Rhino, and Autodesk?
Thank you.
ACarmona_Intel
Hello OnurKARABULUT,
Please generate an SSU report to help me further analyze important details on your system, such as the OS build number, graphics driver version, etc. To generate the SSU report, please refer to the article: How to Use the Display Driver Uninstaller (DDU) to Uninstall an Intel® Graphics Driver. Please send me the generated SSU.txt file.
Carmona A.
ACarmona_Intel
I am checking in with you to see if you already have the information that I requested in order for me to continue to further investigate our issue.
Thank you!
Carmona A.
ACarmona_Intel
This is only a quick follow-up; I just wanted to check in with you, as I haven't received any feedback from you.
Thank you!
Carmona A.
ACarmona_Intel
I hope you are doing well.
Since I have not heard back from you, I will now be closing our case.
If, in case you are just busy and still needed assistance, please submit a new question on our community: https://community.intel.com/, as this thread will no longer be monitored.
Thank you.
Carmona A.
