Intel® Arc™ Discrete Graphics
3499 Discussions
Arc 750 graphic card game error
空空
I am currently using an Intel Arc 750,driver version is 31.0.101.4146
bought Sword and Fairy 7 in steam
Every time I hit the devil in this scene, it will crash
Hugo_Intel
Hello 空空
Thank you for posting on the Intel® ARC™ Graphics Communities. I am sorry to hear that you are experiencing crashes on Sword and Fairy 7 when using your Intel® Arc™ A750 Graphics. Please let's try the following:
1.-Update your Bios to the latest version from your motherboard manufacturer.
2.-Test an older driver to check if the issue is exclusive to newer driver versions. You can test driver version 31.0.101.3959.
If the issue persists, please share with us the following information:
  • Share a short video showing the issue.
  • Share a screenshot of the in-game graphics settings.
  • Is the issue only happening exclusively in that scene? Or does happen in different scenarios?
  • Have you tried disabling the ARc GPU and testing only the integrated GPU?
  • Is Resizable BAR enabled on your system?
Hugo O.
Hugo_Intel
Hello 空空
I hope you are doing fine.
Hugo O.
Hugo_Intel
Hello 空空
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
Hugo_Intel
Hello 空空
Before closing this thread and in case the issue still persists, we would like to provide one more recommendation:
Using Device Manager disable the integrated GPU and use only the ARC GPU for testing:
Go to device manage > Display adapters
Right-click on the Intel(R) UHD Graphics 730
Click disable.
Hugo O.
空空
Hugo_Intel
Hello 空空
Thank you for updating your BIOS and for trying the latest driver. Since the issue still happens we will continue checking this issue internally and once I have an update for you I will post back.
Hugo O.
