Intel® Arc™ Discrete Graphics
3864 Discussions
BSOD 0x000000D1 on Intel Arc B580 (Driver 32.0.101.8509) during Upscayl & DaVinci Resolve Rendering
NightPrince
I am reporting a system instability issue (BSOD) that occurs specifically when my GPU is under heavy load during video rendering and AI upscaling. This started happening immediately after I updated my Intel Arc driver to version 32.0.101.8509.
System Specifications:
  • CPU: AMD Ryzen 7 8700F
  • GPU: Intel Arc B580
  • RAM: 32GB DDR5 6000MHz
  • Driver Version: 32.0.101.8509 (WHQL)
  • Resizable BAR: Enabled
Issue Description: The system crashes and reboots during heavy GPU workloads in DaVinci Resolve (video rendering) and Upscayl (AI image upscaling). On previous driver versions, the system was stable, but version .8509 seems to trigger a memory access violation (Bugcheck 0xD1).
Event Viewer Log (Original):
The computer has rebooted from a bugcheck. The bugcheck was: 0x000000d1 (0xffffa68773f3d83c, 0x0000000000000006, 0x0000000000000000, 0xfffff8067f933c69). A dump was saved in: C:\WINDOWS\Minidump\021526-7031-01.dmp. Report Id: 801542e4-cae3-4db0-8007-1edb505eaf12.
Steps to Reproduce:
  1. Open DaVinci Resolve and start a video render.
  2. Or, use Upscayl to upscale images using the GPU.
  3. The system will crash with the 0xD1 bugcheck after a few minutes of processing.
Thank you.
RedCapsicum9
New Contributor II
That definitely shouldn’t be happening... try rollback to the last stable driver version where BSOD doesn’t occur, disable MFG/XeSS 3 features to reduce GPU stress while rendering.
for your last resort try first this Intel fix: https://www.intel.com/content/www/us/en/support/articles/000098522/processors.html
