Intel® Arc™ Discrete Graphics
3557 Discussions
CALL OF DUTY WARZONE
ALAK
Hi i have problem intel arc 770 on the game before have this card i get nividia 3060 and when i set games to low settings i get 160fps but on this card i have only 100-110 fps but intel arc 770 its better than 3060 but why i get low fps and have glitch by grapichs
JedG_Intel
Hello ALAK,
Thank you for posting at Intel Community Forum
I'd like to gather more information to further investigate the issue you are having, please see below.
1. Did the issue occur right away after using the Arc A770?
2. Is the issue isolated to Call of Duty Warzone?
3. Have you checked the temperatures of your GPU while gaming?
4. Did you make any recent changes to the system aside from the GPU?
5. Is the issue happening on a specific map?
Additionally, to have a better understanding of your system configuration and components please generate System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
I'm looking forward to your response!
Jed G.
ALAK
Yes
call of Duty and The finals
Yes it was 60 c
No
on evrey map
JedG_Intel
Hi ALAK,
Thank you for sharing this information. I would like to give some recommendations that you can try.
1. Set the scaling type to Fixed width under Global settings in Post-processing.
2. Set Adaptive tessellation to 90% under 3D control.
3. Activate Intel Xess to Ultra Quality in-game settings.
For reference: FPS Drops, Performance
In case that you're still having the same issue, I'll need more information from you, please see below.
1. Generate System Support Utility report - How to get the Intel® System Support Utility Logs on Windows*
2. What game settings are you running while using the Arc A770?
3. Capture CapFrameX data
For instructions and steps on how to install and use CapFrameX, please click this link.
I'll be looking forward for your response!
Jed G.
ALAK
1- i have the file uploaded
2- its full low settings with xess (performance)
3- its not work for me only presentmon 2.2
JedG_Intel
Hi ALAK,
Thank you for sharing the additional information.
About the CapFrame data, you said that it was not working. May I know if you are seeing any error messages or could you let me know which step are you having trouble with? Please let me know so I could assist you with it.
I hope to hear from you soon!
Jed G.
JedG_Intel
Hi ALAK,
I'm just following up on the information that I was requesting. Please let me know if there are any challenges so I could help you with it.
Jed G.
JedG_Intel
Hello ALAK,
Jed G.
