Intel® Arc™ Discrete Graphics
3681 Discussions
Fix for being unable to install Intel Arc Control
xela
I recently purchased an Intel ARC A770 but I was unable to install the Intel ARC Control software bundled with the Intel Arc drivers. I read multiple posts on here describing how to fix the issue, but none of the solutions worked for me. However, I ended up finding a fix on my own. It turns out I accidentally installed Windows 11 Pro N instead of the normal Windows 11 Pro. After reinstalling Windows 11 with the correct version (the non-N one), Intel Arc Control installed correctly. I figured I would share this here in case my solution is useful to anyone else.
jhon09
It's great that you were able to troubleshoot and find a solution to the issue with installing the Intel ARC Control software for your Intel ARC A770. Your experience highlights the importance of verifying the Windows version compatibility. Accidentally installing Windows 11 Pro N instead of the standard version can lead to compatibility issues with certain software packages. Thanks for sharing your solution here; it could indeed be beneficial for others who might encounter a similar problem with their Intel ARC drivers and control software installation.
