Intel® Arc™ Discrete Graphics
3498 Discussions
Gears of War Reloaded unplayable on Arc A770 16GB
AI_Legion
So the game launched with intel arc cards in the requirements, yet the game is completely unplayable on an A770 16GB card. Install and play it through either steam or the Microsoft Store.
Gears of War Reloaded is stuttering, freezing, and dropping from 100+fps to less than 5 fps.
I included the intel ssu output and uploaded it as well.
Labels (2)
AI_Legion
Here is a video example of the issue as I experience it.
Note how CPU usage spikes to 90+% when it stutters and drops frames.
I also believe that the video caught the audio skipping as well.
Gears of War Reloaded Poor Performance - YouTube
I do hope that we can have this issue fixed sometime soon.
VonM_Intel
Hi AI_Legion,
Thank you for posting in our Community and for sharing the detailed information, SSU report, and video recording. Could you please confirm the following details to help us reproduce the issue:
  • Were there any recent hardware or software changes made before the issue occurred?
  • Is the game working fine before without any stuttering issues?
  • What in-game settings are being used (resolution, graphics quality, V-Sync, ray tracing, etc.) when the issue happens?
  • Does the issue occur immediately at launch or only after extended gameplay?
  • Have you tried a clean driver installation using DDU (Display Driver Uninstaller) before reinstalling the driver? If you have done any other tests, please let me know the details so we don't cover the same ground twice.
Additionally, I kindly ask you to provide CapFrameX data for this game. This will help us analyze performance metrics more thoroughly and identify any issues. However, please share a CapFrameX file that captures at least 2-5 minutes of gameplay.
Have a nice day!
Von M.
AI_Legion
Okay, so going through the list one at a time:
I haven't changed any hardware in the computer in a few months.
No, the game never worked without this issue.
I've tried all graphics settings, the hitching and frame dropping never stops, but the framerate in the minute seconds between gets better as the settings go down. towards low. I've tested this extensively with both the release build and the open beta they did like 3 weeks ago.
Screenshot of the settings as follows:
 This issue is only present while the game is rendering a 3d scene (so any time you can actually play the game). Menus work fine and the hitching doesn't seem to be present until you start playing. But yes, its starts immediately and doesn't ever go away.
I have DDU and reinstalled this driver, yes. First thing I tried.
This website will not allow me to upload a .json file by itself, so I'm zipping it into a .zip by itself so I can upload it
EDIT/8-29:
Added a longer CapFrameX recording of playing the Lethia mine level.
It seems to even out some after a little while, but textures are very obviously not loading correctly, and any time you transition to a new map, or load any kind of asset the game starts stuttering again, as evident in the recording.
VonM_Intel
Hello AI_Legion,
Thank you for providing the detailed information along with the screenshots and logs. I will review the files you’ve shared and continue investigating to determine the root cause, and I’ll post an update in this thread once I have more information.
Von M.
VonM_Intel
Hello AI_Legion,
Thank you for bringing this performance issue to our attention. We are currently investigating the matter, and once an update becomes available, we will share it promptly. In the meantime, we kindly ask you to re-test using driver version 32.0.101.7029 and adjust the texture quality to Medium or Low. Please confirm the results with us after testing, as this will serve as a temporary workaround while we continue our investigation.
Von M.
AI_Legion
I've tested the workaround, which seems to have temporarily fixed the horrendous stuttering and hitching, which is great news!
Does your test system completely lock up while using CapFrameX? It's done this twice so far on two different drivers.
Windows reliability history doesn't even report a hardware error for me.
(Could be my RAM((Further troubleshooting is necessary.))
VonM_Intel
Hello AI_Legion,
Thank you for the update. I’m glad to hear that the workaround has temporarily resolved the stuttering and hitching. That’s definitely a positive step forward. Regarding the system lock-ups while using CapFrameX, no, our test system has not experienced complete lock-ups during usage. Since you’ve encountered this twice on different drivers without any corresponding hardware errors in Windows reliability history, it does suggest the issue may not be strictly hardware-related. Your suspicion about the RAM is valid, further troubleshooting on that front would be a good next step. If possible, have you tried testing with alternative RAM modules or running a memory diagnostic tool to help rule this out?
Please keep me updated on your findings so we can continue narrowing down the cause together
Von M.
AI_Legion
Believe it or not the lockups are a common thing with this A770 card, I've had the card since June of 2023 and even as the drivers get better, the system remains unstable.
This system has had 2 different sets of DDR4 3200 2x16 kits, one set of G.Skill 3200 previously, and the set installed in it currently is Corsair Vengeance 2x16GB 3200 (16-20-20-38 CAS).
This is relevant because the lockups aren't a new thing, they have persisted across MULTIPLE hardware changes. They seem to be more frequent when running CapFrameX, though.
The factory OC on the video card could be the cause of this because there is NO OC headroom past 2400MHz exactly. (Predator Bi-Frost A770 16GB model) I just don't want to lose any performance backing core clock down like that.
At any rate, I'm going to commit to a 4+hour memtest86 run here after a little bit to eliminate RAM stability as a cause.
