Intel® Arc™ Discrete Graphics
3571 Discussions
Intel ARC Graphics HDMI external connection keeps blanking screen
Andre_Luiz
Hello Everyone.
I got a new laptop at work, about one month ago and it was working great until Tuesday.
I left the office with everything working and now, the monitor attached to the HDMI connector keeps disappearing the image, from time to time, with no pattern, it may take 1 minute, 5 minutes or do it every 30, 20 seconds.
As there was no changes in the Windows/Laptop, cables tested and swapped, monitors also, I called Lenovo and they replaced the motherboard.
The issue persisits even after a new motherboard was installed, so, my best guess, it is a driver issue.
I have ran Lenovo Vantage and got also from here, Intel's support page, the newest drivers. but none solved the problems.
The laptop is a LENOVO 21M8000XBO and the Intel Graphics is this:
Intel® Graphics
Detalhes do driver Atualizado
Provedor: Intel Corporation
Versão: 32.0.101.8135
Data: 2025-09-30
Has anyone faced the same issue with a solution?
Thanks in advance,
Best Regards
JedG_Intel
Hello Andre_Luiz,
To be able to address the issue properly, please share the information below.
1. What monitor are you connecting to (brand, model, resolution)?
2. Is this a direct HDMI connection or are you using any adapters/docking stations?
3. Do you have other ports available (USB-C, DisplayPort)?
Additionally, to have a better understanding of your system configuration and components please generate System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
Best regards
Jed G.
JedG_Intel
Hello Andre_Luiz,
Jed G.
JedG_Intel
Hello Andre_Luiz,
Jed G.
