I am experiencing severe FPS drops and input lag while playing Overwatch with my Intel Arc A770 graphics card. Given that Overwatch has a player base of over 100 million, I believe optimization for this GPU is crucial. Despite having up-to-date drivers and a well-optimized system, the performance issues persist, significantly affecting gameplay.
Please investigate this issue and provide any potential fixes or optimizations.
Thank you.
Merhaba,
Intel Arc A770 ekran kartımla Overwatch oynarken ciddi FPS düşüşleri ve input lag (girdi gecikmesi) yaşıyorum. Overwatch’un 100 milyondan fazla oyuncusu olduğu düşünüldüğünde, bu ekran kartı için optimizasyonun önemli olduğunu düşünüyorum. Sürücülerim güncel ve sistemim optimize edilmiş olmasına rağmen performans sorunları devam ediyor ve oynanışı olumsuz etkiliyor.
Lütfen bu sorunu araştırarak olası çözümler veya optimizasyonlarla ilgili bilgi verin.
Teşekkürler.
Hi sololasido,
I'm sorry to learn that you are experiencing issues with your Intel Arc A770. To better assist you and determine the most appropriate resolution, could you please provide the needed details listed below:
- May I know what digital gaming platform you downloaded Overwatch? is it on blizzard, Steam, battle.net, etc.
- Is the game working fine before? if yes, what are the changes on the system before you encounter the issue?
- When you installed the most recent GPU version, did you run Display Driver Uninstaller first?
- Which troubleshooting techniques have you previously attempted to try to fix the problem?
Kindly run this on your system so that I can also gauge the following peripherals and the driver versions that you have:
Intel® System Support Utility for Windows*
Once finished downloading, open the tool, click on scan (leave the default items checked), click next, then save the system information to a .txt file. Please provide us the .txt file.
Earl E.
Hi sololasido,
Earl E.
Hi sololasido,
Earl E.
