Intel® Arc™ Discrete Graphics
3501 Discussions
Intel Arc Fans Suggestions
addelucas123
New Contributor II
Good morning, I wanted to give you suggestions on the Intel Arc fans, we understand that according to you 90 degrees is considered normal, okay but up to what point of 90 degrees? The air flow issue of Intel Arc fans we would like it to be from 70 degrees cengrades start working at 2050 and 2100 RPM, and from 73 degrees Celsius 2200 to 2250 RPM and from 75 degrees Celsius 2300 to 2350 RPM, because when it reaches 80 or 83 degrees in the games it only reaches 2088 2150 RPM in automatic, That's why we want it to work from 70 degrees at 2050 to 2100 RPM and 73 degrees 2150 to 2200 RPM, a little better in terms of automatic fans, because I'm doing the GPU Stress test on the website, and 76 degrees 1979 and 2109 RPM These are suggestions and very important to take good care of the temperature and control, These are suggestions that I give and my consent to both myself and other Intel users and engineers. You must also accept, please, thank you very much.
1. When it reaches a temperature of 70 degrees, the fan should be operating at 2050 to 2100 RPM
2. When it reaches a temperature of 73 degrees, the fan should be operating at 2150 to 2200 RPM
3. When it reaches a temperature of 75 degrees, the fan should be operating at 2300 to 2350 RPM
https://youtu.be/Sb_Jnq4vxPo
greetings David
LilithTwilight
Who is "we", please talk only for yourself not for others you don't know. For my part I don't want the fan curve to be changed, I like it EXACTLY like it is now.
If YOU want another one, feel free to make your own, you can do this in the ARC Control software in case you did not know, no one forces you to use the automatic setting
