Intel® Arc™ Discrete Graphics
3683 Discussions
Intel Battlemage 580 two Solutions(!!!) : Halo Infinite and nf i2c slave device driver (Code 28)
Radbod
Solution 1 : If you have a missing Driver in the Device Manager (nf i2c slave device driver ) you ll have to install the RGB Control Software. As Example ive a B580 Steel Legend from AsRock, you ll need to install "ASRockPolychrome" and start it.
Solution 2 : Halo Infinte showing "No DX12 Device detected..." .
Navigate to the Halo Infinte Game folder (\Halo Infinite\Content\game\data\hardware) and edit the following file with Notepad/Wordpad "GPU_Intel.cfg"
Ad the following line :
; Battlemage Series
0x8086, 0xE20B, , Ultra; Intel(R) Arc(TM) B580 Graphics
Same can be done for all other Intel Arc Cards, if you need help, ill provide more Data!
DeancR_Intel
Hi Radbod,
Thank you for sharing this to the Community and this is well acknowledged.
Dean R.
