Intel® Arc™ Discrete Graphics
3579 Discussions
Monitor locked at 75hz and Not Showing 100Hz on my samsung ls22d300gaw 21.5 100hz
ARMAN1996
Monitor locked at 75hz and Not Showing 100Hz on my samsung ls22d300gaw 21.5 100hz.please help me out my gpu is Intel Arc A580.
MUC
Honored Contributor I
Please create a Report for Intel Graphics Drivers and attach the output file here.
Kohinoor
Kohinoor
I am having the same issue.
I also have same display but I am using intel UHD graphics.
Hope you have found a solution
PravinS
I am also facing the same issue. Samsung service support is not helping with compatibility list for the monitor.
MUC
Samsung Essential Monitor S3 S30GD
1920 x 1080 @ 100 Hz
1 x HDMI 1.4 (300 MHz TMDS)
According to the monitor's manual (pages 40 and 41), it expects VESA's Coordinated Video Timing - Reduced Blanking (CVT-RB) with a pixel clock of 175.5 MHz at a refresh rate of 75 Hz. This apparently works.
The video timing is not specified for 100 Hz, but the pixel clock is listed as 224.25 MHz. CVT-RB would be 235.5 MHz.
So it's obviously a custom video timing issue.
