Intel® Arc™ Discrete Graphics
3581 Discussions
Shader 6.6 Model (Rematch Game)
Griffith
I got a beta code for the Rematch beta game program, but when i tried to play it , it didn't work because of shader model 6.6 which i support , according my research . please help me look into this. The screenshot is below, i am also using the latest intel graphics version(Version:
32.0.101.6734). My sys:
13th Gen Intel® Core™ i7-13700H
bios ver:UX3404VA.303
RandyT_Intel
Hi @Griffith ,
  • Please provide the SSU log report and share it here so I can review your system's configuration.
  • Could you let me know the origin of the game? Where did it come from, and where did you download it?
  • Have you previously performed a clean installation of the graphics driver, before using either an older or the latest version?
  • Has this happened before?
  • What steps were taken to troubleshoot this issue?
Warm regards,
Randy T.
RandyT_Intel
Hi @Griffith ,
Warm regards,
Randy T.
Griffith
The name of the game is Rematch its a new game, that is yet to release , its really popular.  i got a beta code to be able to play and downloaded from steam .
Yes, my graphics driver was freshly installed based on the version i mentioned.
RandyT_Intel
Hi @Griffith ,
Please kindly try these steps and let me know if there are any changes.
  1. Clean install the graphics driver to the latest version with Display Driver Uninstaller (DDU). How to Use the Display Driver Uninstaller (DDU) to Uninstall an...
    1. Download Display Driver Uninstaller (DDU) software and extract the file.
    2. Open DDU ****.exe and extract program.
    3. Reboot into Windows* safe mode. (Refer to Start your PC in safe mode in Windows.)
    4. Go to the DDU extract path and double-click the Display Driver Uninstaller.exe to open the DDU.
    5. Click Close in the Options window.
    6. Select device type to GPU and select device to INTEL.
    7. Click Clean and restart, wait for the software to finish the process, and auto-reboot Windows to normal mode.
  2. Download and install the graphics driver 32.0.101.6737 (WHQL Certified) on Download Center.
Warm regards,
Randy T.
RandyT_Intel
Hi @Griffith ,
I'm following up on the previous recommendation I provided. Have you had a chance to review the information and apply it to your system? Please let me know the outcome so I can determine the next best course of action.
Warm regards,
Randy T.
Griffith
 i have done t, but unfortunately the beta test is over so i cant confirm if it worked. when the game is available, i will make sure to let you know.
RandyT_Intel
Hi @Griffith ,
Thank you for informing us. I will proceed with closing this case for now. Once the information becomes available, you may submit a new ticket, and we will continue assisting you with this concern.
Warm regards,
Randy T.
