Intel® Arc™ Discrete Graphics
4149 Обсуждение
Title: Intel Arc B580 Graphics Card Random Freezing Issue
TaiwanLouis
Новичок
4 776Просмотр.
I am experiencing an issue with the Intel Arc B580 graphics card, where the system randomly freezes without warning.
This problem occurs during normal usage, especially while playing games such as MapleStory and other PC games. When the freeze happens, the screen becomes unresponsive, but audio may continue playing in the background, and the system does not recover on its own.
I have tested multiple driver versions, including:
  • Intel Graphics Driver v32.0.101.8132 (WHQL)
Unfortunately, the freezing issue still occurs across these driver versions.
Additionally, the issue becomes more frequent and more severe when Resizable BAR (ReBAR) is enabled in the motherboard BIOS. After disabling ReBAR, the freezing happens less often, but the problem is not completely resolved.
This behavior makes the system unstable for gaming and daily use. I hope Intel can further investigate the compatibility between the Arc B580, driver versions, and Resizable BAR support.
If anyone has experienced a similar issue or found a stable driver or BIOS configuration, please feel free to share your solution.
0 баллов
13 Ответы
KentRusselP_Intel
Модератор
4 766Просмотр.
Hi TaiwanLouis,
Thank you for reaching out to the Intel Community Forum. I appreciate your message and want to assure you that I’m here to assist you with your concern. To better understand the issue and provide accurate support, could you please share the following details:
  • What is the model of your power supply (PSU)?
  • Is this a completely new build, or did you upgrade from a previous GPU?
  • Is the GPU connected directly to the motherboard, or are you using a PCIe riser cable?
  • What are your GPU temperatures at idle and under load during gaming?
  • Have you checked GPU power consumption when the system freezes?
  • Are all required PCIe power connectors firmly seated on the GPU?
  • How long can you typically play before the freeze occurs?
  • Do the freezes happen during specific in-game actions or randomly?
  • Does the issue also occur during non-gaming tasks (e.g., video playback, web browsing, idle)?
  • When the system freezes, do keyboard shortcuts like Ctrl+Alt+Del or Alt+Tab still respond?
  • Are there any error messages in Windows Event Viewer after a forced restart?
  • Does the system freeze when you run a GPU stress test?
  • Are you using any GPU monitoring or overclocking tools (e.g., MSI Afterburner)?
  • Have you tried using Display Driver Uninstaller (DDU) before updating the graphics driver?
  • Have you tried to update to ⁠Intel® Graphics Driver 32.0.101.8331 (WHQL Certified)?
Additionally, to help us better understand your system configuration and provide accurate support, we kindly request that you share the Intel® System Support Utility (SSU) logs from your device. These logs contain important details about your hardware and software environment, which are crucial for troubleshooting.
Please follow these steps:
  1. Download and run the Intel® SSU application.
  2. The tool will generate a text file containing your system information.
  3. Refer to this guide for detailed instructions: Help Guide for the Intel® System Support Utility
  4. Once completed, please attach the generated file to your response.
If you have any additional questions or need further assistance, please don’t hesitate to contact us.
Kent Russel P.
TaiwanLouis
Новичок
4 690Просмотр.
Power Supply: SilverStone 650W, 80 PLUS certified
The graphics card was upgraded from a previous GPU
The graphics card is directly connected to the motherboard
Not tested — the issue occurs even when not playing games
All power connectors are firmly connected to the GPU
The issue occurs randomly
In-game stuttering/freezing occurs in MapleStory
The issue also occurs during non-gaming tasks (e.g., video playback, web browsing, or idle state)
When the system freezes, the display is frozen but keyboard input still responds and audio continues playing
After a forced reboot, no error messages appear in Windows Event Viewer
No GPU stress testing has been performed
No GPU monitoring or overclocking tools are in use
Before updating the graphics driver, Display Driver Uninstaller (DDU) was used
After updating to Intel® Graphics Driver 32.0.101.8331 (WHQL certified), the issue occurs more frequently
KentRusselP_Intel
Модератор
4 635Просмотр.
Hi TaiwanLouis,
I hope you’re doing well, and thank you for getting back to me! To assist with further analysis and investigation, could you please provide details on the following:
  1. SilverStone 650W PSU Model – The exact model number is important because the Arc B580 requires substantial power (190W TGP), and combined with your i7-12700 (65W base, up to 180W boost), your PSU may be operating near its limit.
  2. Memory Configuration – You have 32GB in a single DIMM (Kingston KHX3200C16D4/32GX), but it’s running at 2400 MT/s instead of the rated 3200 MT/s. Have you enabled XMP/DOCP in BIOS to achieve the correct speed?
  3. BIOS Mode – Your BIOS is currently in Legacy mode. Have you tried switching to UEFI? Legacy BIOS can sometimes cause compatibility issues with modern GPUs.
  4. BIOS Version – You’re on version 1.M0 (April 2025). Please update to the latest version for your motherboard: 7D43v1N1. Here is the link for your reference: https://www.msi.com/Motherboard/PRO-B660M-A-DDR4/support
  5. Driver Rollback – Since the issue worsened with driver 32.0.101.8331, could you roll back to the previous version and test for a few days?
  6. Temperature Monitoring – Please install HWiNFO64 and monitor GPU temperatures during the next freeze. Even light tasks can trigger instability if overheating occurs.
  7. PCIe Settings – In BIOS, what PCIe generation is your GPU slot set to (PCIe 3.0/4.0/Auto)? Have you tried manually setting it to Gen 3.0 to check if stability improves?
If you have any questions or need clarification, please don’t hesitate to reach out.
Kent Russel P.
TaiwanLouis
Новичок
4 546Просмотр.
Here is the updated information based on your questions: but the system still experiences random freezes.
Power Supply: SilverStone SST-ET650-G (650W)
Memory Configuration:
32GB single DIMM (Kingston KHX3200C16D4/32GX).
XMP has been enabled in BIOS, and the memory is now running at 3200 MT/s.
BIOS Mode:
BIOS has been switched from Legacy to UEFI.
BIOS Version:
Updated to the latest version 7D43v1N1.
PCIe Settings:
GPU slot has been manually set to PCIe Gen 3.0,
TaiwanLouis
Новичок
4 540Просмотр.
I have already tested the following driver versions: gfx_win_101.8136, gfx_win_101.8250, gfx_win_101.8247, and gfx_win_101.8331, and all of them exhibit the same freezing issue.
Sheperd404
Начинающий
4 486Просмотр.
Same issue, happens randomly, can be 10 min can be hours, ive ran stress tests and it is fine, but its so random, screen goes black audio keeps going for like 10 seconds, have to reboot to get video/audio again
KentRusselP_Intel
Модератор
4 391Просмотр.
Hi TaiwanLouis,
I hope you are doing well and thank you for getting back! For further investigation of the issue, please answer the following questions:
  1. How old is this PSU? The Arc B580 (190W) + i7-12700 (up to 180W) + system components could be pushing this 650W unit to its limits, especially if it's aging.
  2. Can you use DDU to completely remove the current driver 32.0.101.8331 and install the older 32.0.101.8132 version that you mentioned had fewer issues? Test this for several days. Here is the link for your reference: https://www.intel.com/content/www/us/en/download/785597/865175/intel-arc-graphics-windows.html
  3. Have you installed HWiNFO64 or GPU-Z to monitor temperatures? What are your GPU temps during: Idle, Light gaming, and The moment before/during a freeze?
  4. Can you run Windows Memory Diagnostic or MemTest86 overnight to rule out RAM issues?
  5. Do you have another 32GB stick to test dual-channel configuration, or can you borrow a smaller kit (2x16GB) to test?
  6. When the system freezes with "display frozen but audio continues," can you move the mouse cursor? (Does it move but screen doesn't update?) and can you hear system sounds/notifications continuing?
  7. Can you test with a different PSU (700W+ from a friend) for a few days? This would definitively rule out power delivery issues.
If you have any questions or need further clarification, please don’t hesitate to reach out.
Hi Sheperd404, please create a separate Intel Community post for accurate and effective support.
Kent Russel P.
TaiwanLouis
Новичок
4 367Просмотр.
Thank you for your detailed suggestions. I will respond point by point below for clarity:
PSU aging concern
The system freezes even when I am only browsing the web, without gaming or heavy load.
This issue does not occur when I use other graphics cards in the same system.
Based on this, I believe PSU aging or insufficient wattage can reasonably be ruled out.
DDU and driver testing
I have already used DDU multiple times to completely remove the drivers and tested several older versions.
The freezing issue still occurs on all of them, including versions newer than gfx_win_101.6325 / 101.6252.
Only gfx_win_101.6325 / 101.6252 works normally without freezing.
I purchased this graphics card this year, and the issue did not exist when I first installed it.
The problem only started after updating to newer Intel drivers, which strongly suggests a driver-related regression.
Temperature monitoring
What temperature range do you consider abnormal for the Arc B580?
I have spent a significant amount of time monitoring temperatures and stress testing, but no thermal abnormalities were found.
If temperatures were the root cause, the issue should also appear on older drivers.
Why does gfx_win_101.6325 / 101.6252 operate normally under the same temperatures?
Memory diagnostic testing
Please clarify what you consider a “passing” standard for overnight memory tests.
I have already invested a large amount of time testing system stability.
Again, if RAM were the issue, the freezing should also occur on gfx_win_101.6325 / 101.6252, which it does not.
Freeze behavior details
When the system freezes with “display frozen but audio continues”:
The mouse cursor cannot be moved
System sounds and notifications continue
Discord voice chat continues to function normally
This behavior strongly indicates a GPU display driver hang, not a system-wide crash or power issue.
Testing with another PSU
I do not have access to another PSU at the moment.
If I need to purchase a new PSU solely for testing, at that point I would realistically consider purchasing a different graphics card instead.
Given all the above, the evidence consistently points to a driver issue introduced after gfx_win_101.6325 / 101.6252, rather than hardware, power, temperature, or memory problems.
I would appreciate further investigation on why newer driver versions cause this issue while 101.6325 / 101.6252 remains stable.
Thank you for your assistance.
KentRusselP_Intel
Модератор
4 280Просмотр.
Hi TaiwanLouis,
Thank you for getting back and I hope you are doing well! Rest assured that we are investigating the issue, For the meantime, if you have any questions or need further clarification, please don’t hesitate to reach out.
Kent Russel P.
KentRusselP_Intel
Модератор
3 342Просмотр.
Hi TaiwanLouis,
I hope you're doing well and thank you for patiently waiting! Upon further investigation, please try the following:
  1. Upon checking, your current OS build is Build 22631.4460 possibly Windows 11 22H2. With that being said, please try to update your Windows if there is any pending window updates
  2. Upon checking your SSU logs, it shows BIOS Mode: Legacy while Secure Boot State: On. With that being said, please have try changing BIOS mode to UEFI. Legacy/CSM mode typically precludes Secure Boot; this mismatch suggests either a reporting anomaly or mixed boot configuration.
  3. Upon checking your BIOS, we were able to confirm that there is a new BIOS Release from PRO B660M-A DDR4 Motherboard M-ATX - Intel 12th Gen Processors, please try and see if there would be any improvements.
Kent Russel P.
JedG_Intel
Модератор
3 117Просмотр.
Hi TaiwanLouis,
I wanted to check if you had the chance to review the recommendations we posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Jed G.
KentRusselP_Intel
Модератор
2 936Просмотр.
Hi TaiwanLouis,
I hope you're doing well. As I haven’t received a response, I will proceed to close this inquiry. Should you require further assistance or have additional questions, please feel free to submit a new request. Kindly note that this thread will no longer be monitored once closed.
Kent Russel P.
DukkyJr
Начинающий
1 908Просмотр.
Hi KentRusselP_Intel
I am also experiencing the same issue. would you prefer me to start a new topic or continue on this one?
I'm curranty on drivers 32.0.101.8425 and it has occurred twice so far. Once on Monday while playing a game and today while watching a video via Firefox.
With both my freezes, audio would still be playing, volume control would still work from keyboard and mouse curser can be seen moving around/across both the screens.
Not done any testing yet because I have only had this card for about 9 days so far after replacing my AMD rx590.
Ответить
