Intel® Arc™ Discrete Graphics
3550 Discussions
Vulkan Lockup Issue on Intel Arc A750
Jegyzettömb
I am experiencing a consistent short freeze (~40 seconds) on the first launch of Vulkan-based games on my Intel Arc A750. This freeze occurs randomly during gameplay, most noticeably when the game is loading caches. Once it completes, the issue does not occur again while the system remains powered on. During the freeze:
  • The game continues to run in the background.
  • Sound output is fine, but my microphone stops working.
  • The Caps Lock indicator can initially blink, but keyboard input eventually stops responding.
  • No black screen or crash occurs, and after ~40 seconds, everything returns to normal.
I have tested with multiple Vulkan games; the issue only occurs with recent Intel Arc drivers. Using the driver version 32.0.101.6737, the problem disappears completely. Updating to any newer driver reproduces the freeze immediately.
Steps already tried:
  • Clean driver reinstall using DDU
  • Deleting game/cache folders
  • Testing in windowed and fullscreen modes
  • Verifying RAM, GPU temperature, and power settings
  • Vulkan SDK reinstallation
This appears to be a driver-specific issue with the Vulkan implementation on newer Intel Arc drivers. No errors are logged.
DeancR_Intel
Hi Jegyzettömb,
Thank you for your continued patience as I've been investigating the Vulkan freeze issue you're experiencing with your Intel Arc A750 GPU.
I have an update on our investigation. I attempted to replicate the ~40 second Vulkan freeze issue you reported in both Baldur's Gate 3 and PEAK in our testing environment. However, after extensive testing (playing for more than 5 minutes in each game), I was unable to encounter the same freeze behavior that you're experiencing.
This suggests that the issue may be isolated to your specific system configuration rather than being a widespread driver regression affecting all users with similar setups.
I would like to share the video of the simulation with regards to the issue for reference.
To further isolate whether this is a system-specific issue, I need to ask you to perform one additional troubleshooting step. Please consider reinstalling your operating system, as there may be corrupted system files or conflicting software components that are contributing to this Vulkan freeze behavior.
I understand that reinstalling the OS is a significant step, but given that:
  • The issue persists across multiple driver versions
  • We cannot reproduce it in our testing environment
  • You have a unique motherboard configuration (QIYIDA X99-D4)
A clean OS installation may help identify if there are underlying system conflicts causing this specific Vulkan implementation issue.
Before proceeding with the OS reinstallation, please ensure you have backups of all important data and software.
Please let me know if you're willing to try this step, or if you have any questions about the process.
Dean R.
DeancR_Intel
Hi Jegyzettömb
Thank you for reaching out regarding the consistent freeze issue you're experiencing with Vulkan-based games on your Intel Arc A750. I appreciate the detailed information you've provided about the symptoms and the comprehensive troubleshooting steps you've already taken. Your systematic approach to identifying that this issue is specific to newer Intel Arc drivers and that it resolves with driver version 32.0.101.6737 is very helpful for our investigation.
I acknowledge your thorough testing, including clean driver reinstalls using DDU, deleting game/cache folders, testing in different display modes, and verifying hardware components. The fact that you've isolated this to a driver-specific issue with the Vulkan implementation is valuable information for our engineering teams.
To better assist you with this issue, could you please provide the following information:
  1. A short video clip of the freeze occurring if possible? This visual documentation would be extremely helpful for our development teams.
  2. The specific Vulkan games that are affected by this issue? Knowing the exact titles will help us understand if this affects all Vulkan games or specific ones.
I recommend trying the latest driver version 32.0.101.7028, which you can download from the following link: Intel Arc & Iris Xe Graphics Driver. Please perform a clean installation using Display Driver Uninstaller (DDU) if possible, as this can help resolve any potential driver conflicts.
For faster communication and assistance, I am available for a phone call. Please let me know a convenient time for you, and I'll ensure we connect promptly to discuss this issue further and potentially escalate it to our engineering teams for deeper investigation.
Your cooperation in providing this information is greatly appreciated, and it will help us assist you more effectively. Thank you for your detailed report and patience as we work to resolve this matter.
Dean R.
Jegyzettömb
Hello, thank you for your reply.
The issue occurs in at least two Vulkan games I play regularly: PEAK and Baldur’s Gate 3. In both cases the freeze happens only once after the first launch of the game.
(I have also tested with DXVK and with DirectX, and in both cases I did not encounter this problem.)
I tried the latest driver version 32.0.101.7028 as you suggested, but unfortunately the freeze still occurs with it.
I started recording from the game launch and cut out about one minute of unnecessary footage before the freeze. The video shows the freeze occurring and then returning to normal.
DeancR_Intel
Hi Jegyzettömb
Thank you for the additional information and for testing the latest driver version 32.0.101.7028. I understand how frustrating this must be, especially since you've identified that the issue is specific to newer Intel Arc drivers and have done such thorough troubleshooting on your end.
Your detailed testing with PEAK and Baldur's Gate 3, along with the confirmation that DXVK and DirectX don't exhibit this problem, provides valuable insight into this being a Vulkan-specific driver issue. The video documentation you've provided will be extremely helpful for our investigation.
To better assist you with this driver-specific Vulkan issue, could you please provide the following information:
A System Support Utility (SSU) report? This will give us detailed information about your system configuration. If you're not comfortable generating an SSU report, could you please share:
  • Your CPU model
  • Motherboard model
  • Current BIOS version
Could you please check and provide any error logs from Event Viewer during the time when the freeze occurs? Even though you mentioned no errors are logged, there might be system-level events that could help us understand what's happening during the freeze.
This information will help us understand your complete system configuration and assist in our investigation of this Vulkan implementation issue with the newer Arc drivers.
I appreciate your patience and the comprehensive documentation you've provided. Your systematic approach to isolating this issue has been invaluable, and we'll work to get this resolved for you.
Dean R.
Jegyzettömb
Thank you for your response and for your guidance on this issue. I’ve generated the requested System Support Utility (SSU) report, which I’ve attached to this message.
Additionally, I’ve reviewed the Event Viewer and included the logs corresponding to the moment when the Vulkan freeze occurred. While the system did not experience a full crash or Blue Screen, these logs capture the relevant events during the freeze.
Please let me know if any further information or logs would be helpful for your investigation. I hope this helps in diagnosing the Vulkan-specific issue.
DeancR_Intel
Hi Jegyzettömb,
Thank you for providing the System Support Utility (SSU) report and Event Viewer logs. I truly appreciate your continued cooperation and the comprehensive documentation you've provided throughout this investigation.
Your systematic approach to isolating this Vulkan-specific issue has been exceptional, and the additional system information and event logs you've shared will be crucial for our analysis. The fact that you've confirmed this occurs specifically with PEAK and Baldur's Gate 3 using Vulkan, while DXVK and DirectX work without issues, along with the video documentation showing the exact freeze behavior, provides us with a clear picture of the problem.
Given the driver-specific nature of this issue (working with 32.0.101.6737 but not with newer versions including 32.0.101.7028), and the detailed evidence you've provided, I will be conducting a further investigation into this Vulkan implementation issue with the newer Intel Arc drivers. I'll get back to you with an update once more information becomes available from this investigation.
Dean R.
DeancR_Intel
Hi Jegyzettömb,
Thank you for the comprehensive documentation you've provided for this Vulkan driver regression issue. Your systematic approach and detailed evidence have been invaluable for our investigation.
To help us focus our troubleshooting efforts more effectively, I need to narrow down our investigation scope. Could you please identify which specific game you'd like us to prioritize for our analysis - either PEAK or Baldur's Gate 3? Once you've selected the game, please also provide your current in-game graphics settings for that title, as this will help us replicate the issue more accurately.
Additionally, I reviewed your SSU report and noticed that we need some additional system information. Could you please provide:
System Information:
  • Your exact motherboard model and current BIOS version
  • Please update to the latest BIOS version if you haven't already done so, as BIOS updates can sometimes resolve compatibility issues with newer drivers.
This focused approach will allow us to conduct a more targeted investigation into the Vulkan implementation changes between driver versions and help us identify the root cause of this regression more efficiently.
Dean R.
Jegyzettömb
For your investigation, please use Baldur’s Gate 3. The issue occurs regardless of in-game graphics settings – it happens on both the lowest and the highest (Ultra) presets (I personally play on High settings, with FSR 2 set to Quality).
Regarding my system: I am using a QIYIDA X99-D4 motherboard. The BIOS version shows as 0.01 x64 (no official updates are available for this model, and this BIOS has caused no issues so far).
DeancR_Intel
Hi Jegyzettömb,
Thank you for selecting Baldur's Gate 3 as the priority game for our investigation and for providing the motherboard information. I appreciate you confirming that the issue occurs regardless of graphics settings, from lowest to Ultra presets, which helps us understand that this is a consistent Vulkan driver issue rather than being tied to specific graphics configurations.
Your QIYIDA X99-D4 motherboard information and BIOS version 0.01 x64 have been noted. Since no official BIOS updates are available for this model and it hasn't caused other issues, we'll proceed with the current configuration.
Given the comprehensive documentation you've provided - including the SSU report, Event Viewer logs, video evidence, and confirmation that the issue affects Baldur's Gate 3 consistently across all graphics settings - I will be looking into this Vulkan driver regression issue further internally.
Thank you for your exceptional patience and thorough documentation throughout this process.
Dean R.
DeancR_Intel
Hi Jegyzettömb,
Thank you for your patience while we investigated the Vulkan freeze issue you're experiencing with your Intel Arc A750 GPU in Baldur's Gate 3 and other games.
I wanted to provide you with an update on our investigation. We have attempted to reproduce the ~40 second Vulkan freeze issue you reported on first game launch, but were unable to encounter the same problem in our testing environment. This suggests there may be specific system configurations or steps that are necessary to trigger this issue.
To help us better understand and reproduce this problem, could you please provide additional information about:
Are there any particular steps you take when launching Baldur's Gate 3 that might be relevant (e.g., launching through Steam, specific game settings, background applications running)?
Any specific BIOS settings, Windows configurations, or other software that might be contributing to this issue?
After completing the clean installation, please test Baldur's Gate 3 again and let me know if the issue persists.
If the problem continues after the clean driver installation, or if you can provide the additional reproduction details, I will investigate this issue again for further investigation. Thank you for your continued cooperation in helping us resolve this Vulkan driver issue.
Dean R.
Jegyzettömb
I made a mistake when I previously suggested focusing on Baldur's Gate 3, as the issue occurs at very variable times in that game. The problem appears much faster in PEAK, typically within 1–2 minutes, especially around the mirror area, as shown in the video I previously provided. I suggest using PEAK for testing, as it reproduces the problem more consistently.
In my BIOS, Resize BAR is enabled.
In Windows, there are no extra background applications running beyond the default system processes.
DeancR_Intel
Hi Jegyzettömb,
Thank you for the clarification regarding the reproduction steps and for suggesting PEAK as the primary test case. I appreciate you pointing out that PEAK reproduces the issue more consistently (within 1-2 minutes, especially around the mirror area) compared to Baldur's Gate 3 where the timing is more variable.
I have noted the following key details for investigation:
  • Primary test game: PEAK (more consistent reproduction)
  • Reproduction location: Mirror area in PEAK
  • Timing: Issue occurs within 1-2 minutes
  • BIOS setting: Resize BAR enabled
  • System state: No extra background applications running
Given the specific nature of this Vulkan driver regression issue and the comprehensive documentation you've provided, I will be checking this internally for further analysis. The fact that this issue is isolated to newer Intel Arc drivers (working with 32.0.101.6737 but not with 32.0.101.7028) indicates a specific regression that requires detailed investigation.
I will be reviewing:
  • The Vulkan implementation changes between driver versions 6737 and newer releases
  • Your video documentation showing the freeze behavior in PEAK
  • SSU report and Event Viewer logs you provided
  • The specific system configuration factors (QIYIDA X99-D4 motherboard, Resize BAR enabled)
I will get back to you with an update from my internal investigation when I have the necessary information you need.
Thank you for your exceptional patience and the thorough documentation you've provided throughout this process. Your systematic approach to isolating this issue has been invaluable.
Dean R.
DeancR_Intel
Hi Jegyzettömb,
Intel has just released a new graphics driver that may resolve the issue you've been experiencing.
New Driver Available: Intel® Arc™ & Iris® Xe Graphics - Windows* Version: 32.0.101.7029 Download Link: https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
For best results, I recommend performing a clean installation using Display Driver Uninstaller (DDU):
  1. Test your graphics functionality to see if the issue is resolved
DDU Instructions: Please follow the detailed guide here: https://www.intel.com/content/www/us/en/support/articles/000091878/graphics.html
This clean installation method ensures no conflicting driver files remain on your system, which often resolves persistent graphics issues.
After installing the new driver, please let me know:
  • Whether the issue has been resolved
  • If you continue to experience any problems
  • Any changes or improvements you notice
Dean R.
Jegyzettömb
I tested the newly released driver version 32.0.101.7029 using a clean installation with DDU, but unfortunately the Vulkan freeze issue still persists. The behavior is the same as before.
DeancR_Intel
Hi Jegyzettömb,
Thank you for promptly testing the newly released driver version 32.0.101.7029 with a clean DDU installation. I appreciate your thoroughness in following the recommended installation process.
I understand your disappointment that the Vulkan freeze issue persists with the same behavior as before, despite the latest driver release. Your consistent testing and detailed feedback throughout this investigation have been invaluable.
Given that:
  • The issue continues with driver 32.0.101.7029
  • You've confirmed it still occurs in PEAK (within 1-2 minutes, especially around the mirror area)
  • The problem remains isolated to newer Intel Arc drivers (working with 32.0.101.6737)
  • You've provided comprehensive documentation including video evidence, SSU reports, and Event Viewer logs
I will be conducting a more detailed internal investigation into this Vulkan driver regression issue. The persistence of this problem across multiple driver releases, combined with your systematic documentation, indicates this requires specialized analysis of the Vulkan implementation changes between driver versions.
I will review this internally and get back to you with an update once I have more information from this investigation. Your patience and exceptional cooperation in documenting this issue are greatly appreciated.
Thank you for continuing to work with me on resolving this Vulkan freeze issue.
Dean R.
DeancR_Intel
Hi Jegyzettömb,
Dean R.
Jegyzettömb
At this time, a full OS reinstallation is not an option for me.
Since driver version 32.0.101.6737 works without the Vulkan freeze issue, I will continue using that version for now.
You can go ahead and close the topic. Thank you for your support.
DeancR_Intel
Hi Jegyzettömb,
Thank you for your response and for your understanding regarding the OS reinstallation recommendation. I completely respect your decision that a full OS reinstallation is not feasible at this time, and I appreciate your patience throughout our extensive investigation.
I understand that you'll continue using driver version 32.0.101.6737, which provides you with stable Vulkan performance without the freeze issues. This is certainly a practical solution given your current circumstances.
I want to thank you for your exceptional cooperation, detailed documentation, and systematic approach throughout this investigation. Your thorough testing and clear communication made this investigation as comprehensive as possible.
Should you decide to pursue this issue further in the future or if circumstances change regarding the OS reinstallation option, please don't hesitate to reach out. We'll be happy to continue investigating this Vulkan implementation issue.
Thank you again for working with us on this matter.
Dean R.
DeancR_Intel
Hi Jegyzettömb,
Thank you for your patience throughout our investigation of the Vulkan freeze issue you've been experiencing with your Intel Arc A750 GPU.
After extensive testing and analysis, including multiple driver versions, system configuration reviews, and attempted reproduction in our testing environment, I was unable to replicate the ~40 second Vulkan freeze issue you reported in PEAK and Baldur's Gate 3. This suggests the issue may be related to specific system configurations or game-specific interactions that are unique to your setup.
Since this appears to be a game-specific issue that we cannot reproduce in our standard testing environment, I recommend also contacting the PEAK game developer directly for additional support. They may have insights into specific system configurations or Vulkan implementation details that could help resolve this issue.
You can contact Landfall (PEAK developer) at: Contact — Landfall
The game developers may be able to provide specific troubleshooting steps or identify known compatibility issues with certain system configurations that could explain the behavior you're experiencing.
As you mentioned, driver version 32.0.101.6737 continues to work reliably for your system without the Vulkan freeze issues. This remains a viable solution while you explore additional support options with the game developer. I will be closing this thread and no longer be monitored.
Dean R.
Jegyzettömb
Reinstalling Windows solved the problem.
