Intel® Arc™ Discrete Graphics
3569 Discussions
upgraded to b580 and my refresh rate is locked
HDAJSlye
when I upgraded to a b580 from a 3060 8GB my main monitor that I use DP on went from 170hz down to 120hz and my other monitor that uses HDMI went from 120hz to 75hz. I have updated my drivers for the GPU and the monitors as well as update my windows. When I first got the card it used to do the right hz per monitor then after one day it just stopped and caped the hz at lower rates.
HDAJSlye
adding the screenshots of the intel graphics software and windows display settings
VonM_Intel
Hi, HDAJSlye.
Thank you for posting in our Community and for providing the details and the screenshots. I understand that you're facing an issue with refresh rates being capped after upgrading to the B580 graphics. Let's delve deeper into it.
I see that you've provided some of your monitor's specs, but I would need a bit more information about your system configuration. Could you please share the exact make and model of your monitor, as well as the specific model and version of the cables you're using? This will help me determine if there are any compatibility issues with your graphics setup.
Additionally, have you tried DDU or the Display Driver Uninstaller and the SSU logs? While you’ve mentioned your graphics model, I’d like to go a step further and confirm details like your OS build number and check if any errors are logged. The SSU logs can collect that information, which would be very helpful for me in diagnosing the issue.
Have a nice day!
Von M.
VonM_Intel
Hi, HDAJSlye.
Von M.
VonM_Intel
Hi, HDAJSlye.
I have not heard back from you, I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
stedbin
Hello, I have a very similar issue with upgrading from a rx580 to a B580 also.
I can only go up to 120hz with a 144hz monitor using HDMI
With my second monitor that is 75hz I can go to 75hz but the screen resolution is stretched, I can only go 60hz without this issue (DP).
All windows and intel are updated.
