Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
BIOS PASSWORD
Hector_A_
HI:
I'm using the Configuration Profile Wizard and created a USB to copy the settings and everything works fine.  However, I do not see a field where to assign a password to the BIOS. Any help would be appreciated.
These are the settings
Profile Name: Test2
Profile Type: Intel AMT
Network Settings
     FQDN will be the same as the Primary DNS FQDN
     IP will be taken from DHCP
Active Directory Integration
     Active Directory OU:OU=AMT-Intel,DC=MyDomain,DC=Name
Access Control List (ACL)
     User 1: tec.local\Helpdesk Group
          User Type: Active Directory
          User has both remote and local access to the realms listed below
          Realms: Redirection, PT Administration, Hardware Asset, Remote Control, Storage, Event Manager, Storage Administration, Agent Presence Local, Agent Presence Remote, Circuit Breaker, Network Time, General Info, Firmware Update, EIT, Local User Notification, Endpoint Access Control, Endpoint Access Control Administrator, Event Log Reader, User Access Control
     User 2: tec.local\Domain Admins
          User has remote access to the realms listed below
          Realms: Redirection, PT Administration, Hardware Asset, Remote Control, Storage, Event Manager, Storage Administration, Agent Presence Remote, Circuit Breaker, Network Time, General Info, Endpoint Access Control Administrator, Event Log Reader, User Access Control
Home Domains
     Domain 1: MyDomain.Name
     Intel® AMT functionality via VPN is not allowed
Transport Layer Security (TLS)
     Server authentication used for remote interface
     Server Authentication Certificate Properties:
          Certificate Authority: Server.MyDomain.Name\MyDomain-Server-CA
          Certificate Template: WebServer
          Common Names (CNs) in certificate: DNS Host Name (FQDN), Host Name, SAM Account Name, User Principal Name, UUID
Network Configuration
     WiFi
     Enable synchronization of Intel® AMT with host platform WiFi profiles
System Settings
     Enabled Management Interfaces:
     Web UI
     Serial Over LAN
     IDE Redirection
     KVM
          RFB password set
     Power Management Settings: Host is On (S0)
     The Intel® AMT clock will be synchronized with the operating system clock
     Intel® AMT set to respond to ping requests
     Fast Call for Help (within the enterprise network) is Enabled
Joseph_O_Intel1
Hey Hector,
The setting of the BIOS password using the ACUWizard or ACUConfig tools is not possible.
To manipulate the BIOS, it would involve an OEM related tool, such as Dell Client Configuration Toolkit.
Joe
Joseph_O_Intel1
Hey Hector,
The flow above creates a profile that can be pushed to the device via the commandline using acuconfig.
Take a look at the Intel AMT Developers Guide for detailed instructions on using the ACUWizard. The method you used is Method 1 in the linked document.
Joe
Hector_A_
Joe:
thank for the reply.  Actually I have used all four options but I do not see a field where I can input a BIOS password to secure the workstations.  I can do everything else but that and that is the most important thing we're trying to accomplish.  Is there a way to assign a BIOS password using any of the four different ways?  I'm not referring to the MBEX password but the BIOS one.
thank you.
Joseph_O_Intel1
Hey Hector,
Joe
Hector_A_
Thank you Joe.
