Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
Compilation error in WS-management C# applicaion
JaNa
HI every one....
Ihave compiled a sample program of Intel AMT under WS managenet folder. thanbelow error was came....
Error 2 The type or namespace name 'WSManAutomation' could not be found (are you missing a using directive or an assembly reference?) C:\Documents and Settings\Project\Desktop\Project\Vpro\Vpro\5.0.1.4-SDK_5.0\Windows\Intel_AMT\Samples\WS-Management\RemoteControl\c#\RemoteControl.cs 17 7 RemoteControl
I compiled the sample under Windows XP os.
Once i Found some articles to above error it told that the library is comes under Vista or server 2008.
Is that means I cant compile all C# sample codes under XP???????
IF there are way to compile that sample code in XP pls.......... give the way of compiling.....
PLS....
give some solution to the error.
thanx all.....
JaNa
Quoting - dalloun
you are probably missing the WSMAN component for Windows XP. It isavailable for download on microsoft site: http://www.microsoft.com/technet/scriptcenter/newswire/winrm.mspx
This component is already included in Vista OS.
hope that helps.
Dan
JaNa
HI.........
thanx for quick reply..
il install the WINRM and try to compile it again...
thanx again....
