Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
1405 Discussions
Create a local instance of IPS_AlarmClockOccurrence
Shan_A_
I'm just trying to create Alarm Clock with wsman utility, but I couldn't figure out how to do it, can somebody help me?
Trying to execute this command:
root$ wsman put -k ElementName"DefAlert" -k StartTime="2014-07-15T22:00:00Z"-k Interval="PT12M" -k DeleteOnCompletion="true" http://intel.com/wbem/wscim/1/ips-schema/1/IPS_AlarmClockOccurrence?InstanceID="DefAlert" --port 16992 -h 192.168.0.14 --username admin -p "Admin44$" -V -v
I get such response:
<?xml version="1.0" encoding="UTF-8"?>
<a:Envelope xmlns:g="http://schemas.dmtf.org/wbem/wsman/1/cimbinding.xsd" xmlns:f="http://schemas.xmlsoap.org/ws/2004/08/eventing" xmlns:e="http://schemas.dmtf.org/wbem/wsman/1/wsman.xsd" xmlns:d="http://schemas.xmlsoap.org/ws/2004/09/transfer" xmlns:c="http://schemas.xmlsoap.org/ws/2004/09/enumeration" xmlns:b="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:a="http://www.w3.org/2003/05/soap-envelope" xmlns:h="http://schemas.xmlsoap.org/ws/2005/02/trust" xmlns:i="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
  <a:Header>
    <b:To>http://schemas.xmlsoap.org/ws/2004/08/addressing/role/anonymous</b:To>
    <b:RelatesTo>uuid:1e82a3fe-fe28-1e28-8002-e6b2e3bae690</b:RelatesTo>
    <b:Action a:mustUnderstand="true">http://schemas.xmlsoap.org/ws/2004/08/addressing/fault</b:Action>
    <b:MessageID>uuid:00000000-8086-8086-8086-00000000075B</b:MessageID>
  </a:Header>
  <a:Body>
    <a:Fault>
      <a:Code>
        <a:Value>a:Sender</a:Value>
        <a:Subcode>
          <a:Value>b:DestinationUnreachable</a:Value>
        </a:Subcode>
      </a:Code>
      <a:Reason>
        <a:Text xml:lang="en-US">No route can be determined to reach the destination role defined by the WSAddressing To.</a:Text>
      </a:Reason>
      <a:Detail>
        <e:FaultDetail>http://schemas.dmtf.org/wbem/wsman/1/wsman/faultDetail/InvalidResourceURI</e:FaultDetail>
      </a:Detail>
    </a:Fault>
  </a:Body>
</a:Envelope>
Connection failed. response code = 400
 What am I doing wrong?
Colleen_C_Intel
Later versions of AMT (8.0 on) have more alarms and settings. Can you tell us what version of AMT (or what processor) you are running?
Colleen_C_Intel
If you copied your command over, you have syntax errors - try this after your alertname
-h 192.168.0.14 -P 16992 -u admin -p Admin44$ -V -v
Shan_A_
I'm using the AMT 9. As to wsman syntax after IP of AMT host - there are no errors, I've double checked it with Enumerate method and it returned me all the saved alarm instances. But nevertheless there part before IP of host contains errors. I just can't figure out how to construct the command in a right way.
Colleen_C_Intel
Could you send me one of your working commands to show that you are reaching the address because in the above set the error is that you are not reaching it.
Shan_A_
Yes, for example as I've said the enumerate works fine and retrieves all the alarms
$  wsman enumerate http://intel.com/wbem/wscim/1/ips-schema/1/IPS_AlarmClockOccurrence --port 16992 -h 192.168.0.14  --username admin -p "Admin44$" -V -v
<a:Envelope xmlns:a="http://www.w3.org/2003/05/soap-envelope" xmlns:b="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:c="http://schemas.dmtf.org/wbem/wsman/1/wsman.xsd" xmlns:d="http://schemas.xmlsoap.org/ws/2005/02/trust" xmlns:e="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:f="http://schemas.dmtf.org/wbem/wsman/1/cimbinding.xsd" xmlns:g="http://schemas.xmlsoap.org/ws/2004/09/enumeration" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
  <a:Header>
    <b:RelatesTo>uuid:599947a7-fe35-1e35-8002-e6b2e3bae690</b:RelatesTo>
    <b:Action a:mustUnderstand="true">http://schemas.xmlsoap.org/ws/2004/09/enumeration/EnumerateResponse</b:Action>
    <b:MessageID>uuid:00000000-8086-8086-8086-00000000000E</b:MessageID>
    <c:ResourceURI>http://intel.com/wbem/wscim/1/ips-schema/1/IPS_AlarmClockOccurrence</c:ResourceURI>
  </a:Header>
  <a:Body>
    <g:EnumerateResponse>
      <g:EnumerationContext>02000000-0000-0000-0000-000000000000</g:EnumerationContext>
    </g:EnumerateResponse>
  </a:Body>
</a:Envelope>
<a:Envelope xmlns:a="http://www.w3.org/2003/05/soap-envelope" xmlns:b="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:c="http://schemas.dmtf.org/wbem/wsman/1/wsman.xsd" xmlns:d="http://schemas.xmlsoap.org/ws/2005/02/trust" xmlns:e="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:f="http://schemas.dmtf.org/wbem/wsman/1/cimbinding.xsd" xmlns:g="http://schemas.xmlsoap.org/ws/2004/09/enumeration" xmlns:h="http://intel.com/wbem/wscim/1/ips-schema/1/IPS_AlarmClockOccurrence" xmlns:i="http://schemas.dmtf.org/wbem/wscim/1/common" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
  <a:Header>
    <b:RelatesTo>uuid:599b1bd7-fe35-1e35-8003-e6b2e3bae690</b:RelatesTo>
    <b:Action a:mustUnderstand="true">http://schemas.xmlsoap.org/ws/2004/09/enumeration/PullResponse</b:Action>
    <b:MessageID>uuid:00000000-8086-8086-8086-00000000000F</b:MessageID>
  </a:Header>
  <a:Body>
    <g:PullResponse>
      <g:Items>
        <h:IPS_AlarmClockOccurrence>
          <h:DeleteOnCompletion>false</h:DeleteOnCompletion>
          <h:ElementName>DefaultAlarm</h:ElementName>
          <h:InstanceID>DefaultAlarm</h:InstanceID>
          <h:Interval>
            <i:Interval>P1D</i:Interval>
          </h:Interval>
          <h:StartTime>
            <i:Datetime>2014-07-15T13:06:00Z</i:Datetime>
          </h:StartTime>
        </h:IPS_AlarmClockOccurrence>
      </g:Items>
    </g:PullResponse>
  </a:Body>
</a:Envelope>
  <a:Header>
    <b:RelatesTo>uuid:599ba754-fe35-1e35-8004-e6b2e3bae690</b:RelatesTo>
    <b:MessageID>uuid:00000000-8086-8086-8086-000000000010</b:MessageID>
  </a:Header>
  <a:Body>
    <g:PullResponse>
      <g:Items>
          <h:ElementName>newalarm</h:ElementName>
          <h:InstanceID>newalarm</h:InstanceID>
          <h:StartTime>
            <i:Datetime>2014-07-14T17:00:00Z</i:Datetime>
          </h:StartTime>
      </g:Items>
      <g:EndOfSequence/>
    </g:PullResponse>
  </a:Body>
</a:Envelope>
Shan_A_
$  wsman enumerate http://intel.com/wbem/wscim/1/ips-schema/1/IPS_AlarmClockOccurrence --port 16992 -h 134.109.200.143 --username admin -p "Admin44$" -V -v
  <a:Header>
    <b:RelatesTo>uuid:f04c40bf-fe37-1e37-8002-e6b2e3bae690</b:RelatesTo>
    <b:MessageID>uuid:00000000-8086-8086-8086-00000000003D</b:MessageID>
  </a:Header>
  <a:Body>
      <g:EnumerationContext>0A000000-0000-0000-0000-000000000000</g:EnumerationContext>
  </a:Body>
</a:Envelope>
  <a:Header>
    <b:RelatesTo>uuid:f04e4326-fe37-1e37-8003-e6b2e3bae690</b:RelatesTo>
    <b:MessageID>uuid:00000000-8086-8086-8086-00000000003E</b:MessageID>
  </a:Header>
  <a:Body>
    <g:PullResponse>
      <g:Items/>
      <g:EndOfSequence/>
    </g:PullResponse>
  </a:Body>
</a:Envelope>
Shan_A_
Thank you Colleen for your help, I've just find out the right way.
I've looked at the TCP/IP traffic in Wireshark using Intel vPro Poweshel GUITool and found out that in order to set alarm clock I have to use AMT_AlarmClockService Class with only one selector: SystemName="ManagedSystem".  The input template for AddAlarm method, that contains an instance of IPS_AlarmClockOccurance should be passed through a XML file using -J parameter of wsman tool.
So the right commando looks like this:
wsman invoke -a "AddAlarm" -J req2.xml http://intel.com/wbem/wscim/1/amt-schema/1/AMT_AlarmClockService?SystemName="ManagedSystem" -P 16992 -h 192.168.0.14 -u "admin" -p "Admin44$" -V -v
P.S. I've just switched to short parameters, but there is no difference what type do you use --password or -p, --username or -u
Colleen_C_Intel
Thank you for letting us know. We always like to hear things turned out well, even if we didn't help :>}
Sagi__Dotan
Hi Behnam,
I hope all is well with you. I have a question regarding drive model SSDSC2BB016T4.
As you know, our approved FW is G2010141.
However, we have received some drives with a newer FW of G2010150.
Apparently, we cannot downgrade the FW.
What should we do in this case in order to prevent unnecessary RMAs?
My intent is to ensure not getting these new FW loaded drives or to have a way to downgrade it in IVT.
