Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
1412 Discussions
How to discover AMT capabilities at local machine programatically?
Jianjun_G_Intel
I am trying to find a programmatically way to detect the AMT capabilities locally with or without MEI or other driver installed (which is like Platform Discovery Utility do).
Is there any API (C/C++) in the AMT SDK or other packages can do the job?
Joseph_O_Intel1
Hey Jianju
The "Platform Discovery tool" will require the MEI drivers at a minimum, no getting around that requirement. The only way I know of doing a discovery without the use of the MEI is to use a tool called RCMPPing, this tool returns a limited data set of FW version and configuration status.
Gael_H_Intel
Hello - In order to use the AMT API's you need the drivers (MEI) installed.  AMT also needs to be enabled.  You could look up your system on ark.intel.com but if you have a lot of systems, that would take a long time.
Here is the link to the Implementation and Reference Guide - it may help you get started.  Check out the ME WMI provider tool.
https://software.intel.com/sites/manageability/AMT_Implementation_and_Reference_Guide/WordDocuments/intelmewmiprovider.htm
Gael
Jianjun_G_Intel
Gael, thanks a lot, the link is very useful.
I am wondering how Platform Discovery utility tool can detect the ME/AMT info without the MEI driver installed.
Joseph_O_Intel1
Hey Jianju
