Intel® Business Client Software Development
Support for Intel® vPro™ software development and the technologies associated with Intel vPro platforms.
Intel Web UI login fails when password hasn't been changed.
John_F_
I work with a company that uses Intel AMT and recently I've run into a weird problem that is causing major issues for us. When we first setup a computer we provision the computer with a USB stick that was created using the manageability flash drive tool. It sets the MEBX password for the computer.
Recently I've run into an issue where one day I can login to a computer's Intel AMT Web UI using user "admin" and the custom MEBX password...and then I come back to the computer again and I cannot login with those credentials...and yet they haven't been changed. This is a huge problem as I don't have physical access to the computer once we send it out to our customers and I lose the ability to manage computers using AMT when this happens. Can someone explain why I suddenly can't login even though the password was not changed.
Joseph_O_Intel1
Hey John,
I am in need of more answers before i can distinctly say why, so here are a few questions.
  1. Is the device's webUI being accessed locally or by some other device on the network?
  2. Is the OS connected to the network wired or via wireless?
  3. Within the Intel Management and Security status application, go to the advanced tab. Does the device show configured?
  4. if the device is configured go to the extended details screen and look for the IP addresses, compare the IP addresses to that which you are trying to connect to?
Joe
John_F_
    The device's webUI is being accessed by another device on the local network.
    The OS is connected to the network via wired connection.
    Yes it does.
    Yes that is the device IP address I was trying to connect to.
Joseph_O_Intel1
Hey John,
Looks to me like your connection should be solid and your connecting to the correct device. To me it sounds like the password has changed for some reason. As you performed configuration with a USB key, both the AMT and the MEBx password is the same.
So enter the MEBx with your known password, if that works.I would just do a full unconfigure and then activate the network interface. That will return it to a state similar to USB key configuration. Log out of the MEBx and try the remote connection again.
Joe
Thorsten_A_
I'd just like to confirm that I got the same problem as described above yesterday. Everything on my AMT enabled system was configured correctly since weeks (remote access no problem via several ways, i.e. Web Interface, Intel Manageability Commander, Power Shell etc.). Then, after using a wake up script yesterday, it was suddenly not possible anymore to access the Web interface or to use my preconfigured tools. The admin/pwd combination was always beeing rejected.
I did not figure out what the reason of this issue was. I still could access the MEBx with the known password, but every other access was impossible. One week ago I wrote several scripts (PowerShell, DOS commandline), and everything worked as expected, so there could not be any fault on my side. Nor could it has been a network problem because local access was also beeing rejected. It seemed to me as if somebody had altered the AMT user account (admin/pwd), but this was absolutely impossible.
I resolved this issue by deactivating the MEBx completely. A full unprovisioning did not resolve the issue. Besides this I updated the UEFI which in turn also updated the MEBx (Asus Q170M-C mainboard, Intel CPU i7-6700).
It's is clear, that an issue like this is absolutely not acceptable for a business technology like AMT, and I hope that this will never happen again. By request I can provide you with more details (firmware versions etc.). I hope that this was an MEBx firmware issue that has been resolved.
Thorsten
John_F_
My issue has changed a bit since my original post.
The issue I am facing right now is that my desktops will freeze occasionally for unknown reasons. I need the Intel WebUI to remotely reboot devices that freeze. However, when my devices freeze the AMT WebUI locks me out of the device. I can login to the WebUI when the device is powered ON and the OS running, but when a System Hang event occurs the AMT WebUI locks me out.
I've sent several of my known issue devices to Dell to have them look into the issue, but as of right now it's been quite a few months I've had this problem with no resolution in sight.
Joseph_O_Intel1
Hey John,
Dell had a bug a while back in the BIOS/FW and is similar to what you are describing, so my first recommendation would be to update the BIOS and Firmware and let me know your results.
Here is a link to a similar forum post
Joe
John_F_
This is still an issue as of BIOS revision 1.5.7 I will try revision 1.5.9 and see if it helps. I know the Dell 1.5.9 BIOS Release notes have no mention of this latest version being a fix for my issue.
http://www.dell.com/support/home/us/en/19/Drivers/DriversDetails?driverId=8XKRJ&fileId=3647700020&os...
Joseph_O_Intel1
Hey John,
The fix last I heard was going to be released in Mid March, so its not surprising the fix hasn't made it to the Dell download center as of yet.
Joe
Thorsten_A_
My understanding of a reliable remote administration subsystem is that it shall always work. I.e., it should not matter if there is a blue screen, or if the system freezes, or other things.
When I hear problems like this (cannot log into the web GUI when the system freezes) or experience them myself (locked user account) I think it would be better next time to buy a mainboard with a "real" remote control module (IPMI) instead of a BIOS based solution like Intel AMT.
John_F_
Just an update. Dell BIOS Revision 1.5.9 completely locks me out of the Intel AMT UI regardless of system status.
Joseph I've sent your email to the Dell Engineers working with some of my units in case you could help them better understand where we've left things.
