Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
1409 Discussions
Is it possible to connect to an AMT machine without password?
nil123
Hi All,
We have 1000 machine. I want to read/write data from AMT device.
In that case I need to have 1000 user name/ password.
Is it the right approach?
Is it possible to create same user for all machine in network using API.?
for example i want to use a sample 'StorageSamples' for 1000 machine. How will I use that?
Thanks in Advance!!!
Sreelekshm_S_Intel
You have to call these API's separately for each of these systems using its IP address, username and password. There is no way you can use a single call to get info from all these systems. And Intel ME requires you to have a strong password (the default is admin) at the time you set it up in the Bios.
Sree
Lance_A_Intel
Also, you can have the same username/password on each system and allow one user to connect to each machine.
But you must use a password to connect.
jacace
Hello there,
I think you have the perfect scenario for using SCS.
Javier Andrs
