Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
1377 Discussions
KVM doesn't work with the latest Manageability Commander Tool (v. 7.0.11340.2)
Eurosw_vv2
I can't KVM into Intel QM57 based computer (AMT v6.0) using the latest Manageability Commander Tool (v. 7.0.11340.2). I can connect and take control of the computer using Serial-over LAN, but KVM always fails.
KVM works fine with an earlier version of the tool (v6.0.10097.2).
Is there something that needs to be done to make KVM work with the latest commander tool?
Vladimir
Gael_H_Intel
Could you try the latest version of the "Open" DTK? Hopefully this one will work for you. Please let us know.
Larry_M_Intel1
Hello Vladimir,
Are you receiving an error message when you attempt to connect to your client via KVM? Also, what platform are you using? (OEM, AMT version, BIOS version)
I would also recommend using the Open source DTK as Gal mentioned to see if this resolves your issue why we look into this.
The Open sourse version can be found here: http://opentools.homeip.net/open-manageability
