Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
MEBx Error after cmos battery replacement
Luciano_S_
My PC is a Fujitsu mod ESPRIMO P7935 (D2812-A2x) ,Serial: YL1B003165, Bios vers: 6.00 R1.20.2812.A2, o.s.: Windows 7 x64
After battery replacement, after every boot i see the attached error.
If i press a key , Windows will be loaded and run all fine.
I tryed update (again) the bios without success, the function CTRL  P has not effect
I don't use AMT, i I looked for a option in the bios options like "disable AMT" without success
This isssue is for me very serious because this Client is unattended and i can't reboot remotely
Some suggestions?
Thanks very much!!
Luciano
Gael_H_Intel
I looks like you need to reflash the ME (Manageability Engine.)  Did you go to Fujitu's support site and download the correct versions for your system?  If you have tried that and it still doesn't work, you may have to contact their tech support.
Do you have memory DIMMS in bank 0?
Gael
