Intel® Business Client Software Development
Support for Intel® vPro™ software development and the technologies associated with Intel vPro platforms.
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
MeshCommander 0.5.7 with latest NUC 7i5DNHE - wifi profiles problem
CBial
Hi!
I have just received the new NUC7i5DNHE, enabled AMT and started playing with MeshCommander. What I have quickly found is that on this platform it is not possible to add wireless profiles using MeshCommander (it fails silently), but it is possible to do so using default AMT web interface.
Since I have not found any other way of reporting the issue i am reporting it here.
Kind regards,
Chris
Joseph_O_Intel1
Hey Chris,
Thank you for the report of your issue and it has been forwarded to the Mesh Team for analysis. We will update you as soon as we can.
Joe
CBial
Have rechecked this with new edition of MeshCommander (0.5.8) and the problem still remains.
Chris
CBial
Further re-checked with MeshCommander 0.5.9. The problem is still there.
Ylian_S_Intel
Hi. Interesting. I will take a look at it. If I can't find the same problem, I will update MeshCommander to display more feedback so to help debug this.
Ylian
CBial
Ylian,
I know what is the problem!!
1. SSID - by standard the max length is 32 chars. MeshCommander allows only 31. Plain AMT web allows full 32
2. Password - max length allowed is 63 characters. MeshCommander allows only 62. Plain AMT web allows full 63.
My guess is that the problem is ASCIIZ termination. It should be easy to fix.
Kind regards,
Chris
Ylian_S_Intel
That is interesting! I just took a look and MeshCommander did not do any length validation on any of the WIFI profile fields. It just passed the strings as-is to Intel AMT. I just uploaded a new version of MeshCommander v0.5.9 that improves length validation. I did not bump up the version number, so you need to uninstall/download/install if you want to try it.
As for the 31/63 char issues. I don't see it on my computers. Try running MeshCommander like this:
    nw.exe -debug -wsmantrace
You will see all of the Intel AMT traffic. Try adding WIFI profile with a dummy user/ssid/pass and cut & paste the WSMAN call that fails over. I will take a look. It's possible this is a AMT issue, but I can to confirm. If you can also provide the exact Intel AMT version you are using, that would be great.
Ylian
CBial
Ylian,
This is what I have found. With the updated MeshCommander the problem is with SSID when it reaches 32 characters. Like below:
commander.htm:24 WSMAN-SEND(1960): POST /wsman HTTP/1.1
Authorization: Digest username="admin",realm="Digest:70300000000000000000000000000000",nonce="0U1XBs0BAAAAAAAAub/u2kHlkbYopM4K",uri="/wsman",qop="auth",response="057d1096009e9abb0b485967c9af4dde",nc="138",cnonce="l7j2vg0t3xr"
Host: 192.168.12.134:16992
Content-Length: 1659
<?xml version="1.0" encoding="utf-8"?><Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:a="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:w="http://schemas.dmtf.org/wbem/wsman/1/wsman.xsd" xmlns="http://www.w3.org/2003/05/soap-envelope" ><Header><a:Action>http://intel.com/wbem/wscim/1/amt-schema/1/AMT_WiFiPortConfigurationService/AddWiFiSettings</a:Action><a:To>/wsman</a:To><w:ResourceURI>http://intel.com/wbem/wscim/1/amt-schema/1/AMT_WiFiPortConfigurationService</w:ResourceURI><a:MessageID>136</a:MessageID><a:ReplyTo><a:Address>http://schemas.xmlsoap.org/ws/2004/08/addressing/role/anonymous</a:Address></a:ReplyTo><w:OperationTimeout>PT60S</w:OperationTimeout></Header><Body><r:AddWiFiSettings_INPUT xmlns:r="http://intel.com/wbem/wscim/1/amt-schema/1/AMT_WiFiPortConfigurationService"><r:WiFiEndpoint><a:Address>/wsman</a:Address><a:ReferenceParameters><w:ResourceURI>http://schemas.dmtf.org/wbem/wscim/1/cim-schema/2/CIM_WiFiEndpoint</w:ResourceURI><w:SelectorSet><w:Selector Name="Name">WiFi Endpoint 0</w:Selector></w:SelectorSet></a:ReferenceParameters></r:WiFiEndpoint><r:WiFiEndpointSettingsInput xmlns:q="http://schemas.dmtf.org/wbem/wscim/1/cim-schema/2/CIM_WiFiEndpointSettings"><q:ElementName>P5</q:ElementName><q:InstanceID>Intel(r) AMT:WiFi Endpoint Settings P5</q:InstanceID><q:AuthenticationMethod>6</q:AuthenticationMethod><q:EncryptionMethod>4</q:EncryptionMethod><q:SSID>01234567890123456789012345678901</q:SSID><q:Priority>5</q:Priority><q:PSKPassPhrase>012345678901</q:PSKPassPhrase></r:WiFiEndpointSettingsInput></r:AddWiFiSettings_INPUT></Body></Envelope>
commander.htm:19 WSMAN-RECV(1463): HTTP/1.1 400 Bad Request
Date: Thu, 1 Feb 2018 14:44:17 GMT
Server: Intel(R) Active Management Technology 11.8.50.3425
X-Frame-Options: DENY
Content-Type: application/soap+xml; charset=UTF-8
Transfer-Encoding: chunked
Connection: close
Chris
Ylian_S_Intel
Wow, yes, looks like a firmware does not like 32 char long SSID's. Can you let me know the exact version of your Intel AMT? Also, if you have not done so already, try to update your BIOS/AMT to the latest version and try again.
Ylian
CBial
Ylian,
My AMT greets me with following version: v11.80.50. Bit more was actually visible from the log sent previously where I could read: "Server: Intel(R) Active Management Technology 11.8.50.3425".
BIOS is DNKBLi5v.86A.0035.2018.0111.1737 from 1/11/2018. (this BIOS version was actually withdrawn from the Intel website due to microcode patch instability). But, this is the latest BIOS which was available for NUC7i5DNHE.
Ylian, what is interesting in addition is that when AMT is accessed via original web pages (http://A.B.C.D:16992/wlan.htm) then it is possible to add 32 character SSID.
Data as copied from MeshCommander:
Computer model
NUC7i5DNHE
Manufacturer
Intel Corporation
Version
J71740-502
Serial number
XXXXXXXXXXXXXX
System ID
XXXXXXXXXXXXXXXXXXXXXXXXXXXX
Baseboard
Manufacturer
Intel Corporation
Product name
NUC7i5DNB
Version
J57626-502
Serial number
XXXXXXXXXXXXXXX
Asset tag
CIM_Card
Replaceable?
Yes
BIOS
Vendor
Intel Corp.
Version
Release date
1/11/2018
Processor 1
Manufacturer
Intel® Corporation
Version
Intel® Core™ i5-7300U CPU @ 2.60GHz
Maximum socket speed
8300 MHz
Status
Enabled
Chris.
CBial
In addition I have re-checked with MeshCommander 0.6.0 - same issue with 32 character SSID.
