Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
Please help vPro team !!! Exception when running EventLogReader on Linux
Ronnie_S_
Its urgent !!!
When compiling and running the EventLogReader sample on Linux (fedora 22), i encounter an exception when reaching the following line in WSMANCommunicator::ReadRecords() method on WSMANCommunicator.cpp:
messageLog.Get(NULL, this->client);
The exception give error message of:
Failed to establish a connection with server.
Openwsman last error = 2
I have connection with ping to target machine.
I have disabled firewalls.
Running the same sample (C++ version) on same computer on windows with same target machine runs successfully.
1) How to solve error ?
2) does the first parameter in Get method should be a NameValuePair object with key-value of "Name" and "Intel(r) AMT:MessageLog 1", and not NULL (as in windows version of the sample) ?
3
) Any ideas ?
Tnx,
Ronnie
Gael_H_Intel
Hello Ronnie,  I may need to pull in a linux person to help out.  But in order to connect you would need a password and I don't see that in your code.  I will get back with you soon.
Gael
Ronnie_S_
Hi Gael,
I have also tried to run a simple code. on windows it work with no error.
Ported to linux on same machine and same target machine --> got the error !
What can cause error 2 ?
How do i get more information on the problem.
Thx,
Ronnie
