Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
SCS 3.1 troubleshooting
postaquestion
We're trying to implement SCS 3.1 in our company, but we have still problems with provisioning our workstations. In console log we gets all the time the same warnings:
"Cannot create AD AMT Object. Failed on CreateDSObject with computer_name [-2147019886] - Process delayed" or "Exception when trying to push request - 0xCFFF0067. Request is already in queue"
Do you have any suggestions onwhat's wrong?
Ajith_I_Intel
Thanks for the question. Looking from the error logs, it seems like permissions issue. Can you make sure that the SCS user has AD adminrights so that it can create an AD object for the computer that is being provisioned?
If you still encounter the issue afterverifying the permissions, We will need you to send us more information by enabling the full logging capability of the service. You can do this by going into the registry as follows:
Enter a string value V in the following:
HKEY_LOCAL_MACHINE->SOTWARE->Intel->AMTConfServer->LOG then LogLevel
This will create a more detailed log file called: scs_win_server.log We will also need the SCS log containing the described error.
Hope this helps.
Anonymous3
SCS user has AD domain adminrights, follow your suggestion log file was not created :|
I feel desperated :|
adrianfreemantle
Your registry entry should be
[HKEY_LOCAL_MACHINESOFTWAREIntelAMTConfSererLOG]
"LogLevel" = "V"
This has worked for me, you will notice the log files are created in the root of your C: drive.
Also, did you extend all your schemas and run the relevant scripts against your active directory?
Anonymous3
I extended all AD schemas
Listing of a log file:
2007.08.06,12:18:39,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=6020,SOURCE=.mainMainServer.cpp,LINE=398,
Stopping server... (0)
2007.08.06,12:18:39,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5108,SOURCE=.mainConfigurationServer.cpp,LINE=202,
Stopping all managers ...
2007.08.06,12:18:39,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5108,SOURCE=.ManagersHELLOListener.cpp,LINE=26,
Finishing HELLO listener in port 9971.
2007.08.06,12:18:39,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4496,SOURCE=.ManagersHELLOListener.cpp,LINE=132,
HELLO Listener has been stopped.
2007.08.06,12:18:39,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5108,SOURCE=....CommongeneralSCSThread.cpp,LINE=196,
HELLO listener stopped
Poller manager stopped
Queue manager stopped
Delayed manager stopped
Maintenance manager stopped
2007.08.06,12:18:39,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5108,SOURCE=.mainConfigurationServer.cpp,LINE=213,
Server stopped.
2007.08.06,12:18:39,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4160,SOURCE=....CommongeneralSCSThread.cpp,LINE=196,
Configuration Server stopped
2007.08.06,12:18:39,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4160,SOURCE=.mainMainServer.cpp,LINE=412,
Server stopped.
2007.08.06,12:18:39,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4160,SOURCE=.mainMainServer.cpp,LINE=414,
Finishing stopping the server
2007.08.06,12:18:39,ERROR,SERVER=1,USER=PZUintelamt,THREAD=6020,SOURCE=.mainMainServer.cpp,LINE=236,
StartServiceCtrlDispatcher returned
2007.08.06,12:18:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4596,SOURCE=....CommongeneralLogger.cpp,LINE=50,
Found matching messages file (3.1.0.7)
2007.08.06,12:18:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4596,SOURCE=.mainMainServer.cpp,LINE=216,
Starting server
2007.08.06,12:18:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4596,SOURCE=.mainMainServer.cpp,LINE=191,
AMTConfig Service properly installed , continue with start-up
2007.08.06,12:18:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4596,SOURCE=.mainMainServer.cpp,LINE=231,
AMTConfig Service Entered service code
2007.08.06,12:18:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5912,SOURCE=.mainConfigurationServer.cpp,LINE=127,
Checking the user PZUintelamt
2007.08.06,12:18:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5912,SOURCE=.mainConfigurationServer.cpp,LINE=24,
Checking user....
2007.08.06,12:18:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5912 ,SOURCE=.mainConfigurationServer.cpp,LINE=27,
Connecting to the database
2007.08.06,12:18:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5912,SOURCE=.mainConfigurationServer.cpp,LINE=141,
Registering the server
2007.08.06,12:18:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5912,SOURCE=....CommongeneralEnvironment.cpp,LINE=780,
Registering server...
2007.08.06,12:18:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5912,SOURCE=.mainConfigurationServer.cpp,LINE=154,
Starting QUEUE Manager thread
2007.08.06,12:18:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5912,SOURCE=.mainConfigurationServer.cpp,LINE=158,
Starting DELAYED Manager thread
2007.08.06,12:18:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5912,SOURCE=.mainConfigurationServer.cpp,LINE=162,
Starting POLLER Manager thread
2007.08.06,12:18:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5912,SOURCE=.mainConfigurationServer.cpp,LINE=168,
Starting Maintenance Manager thread
2007.08.06,12:18:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5912,SOURCE=.mainConfigurationServer.cpp,LINE=177,
Starting HELLO Listener thread
2007.08.06,12:18:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5912,SOURCE=.ManagersHELLOListener.cpp,LINE=20,
Start HELLO listener as user PZUintelamt, in port 9971.
2007.08.06,12:18:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5912,SOURCE=.mainConfigurationServer.cpp,LINE=181,
Server started with user PZUintelamt.
2007.08.06,12:18:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3988,SOURCE=.ManagersHELLOListener.cpp,LINE=107,
Listening on port 9971 for incoming connections.
2007.08.06,12:18:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
to get request data: pop
2007.08.06,12:18:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=1940,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
Enter Maintenance worker, user PZUintelamt
2007.08.06,12:18:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=1940,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
Maintenance worker pushes request for command_id=17 and uuid=
Maintenance worker pushes request for command_id=18 and uuid=
2007.08.06,12:18:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,12:18:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4932,SOURCE=.WorkersCleanLog.cpp,LINE=15,
Enter Clean log worker, user PZUintelamt
2007.08.06,12:18:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=428,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
Enter Clean status of requests worker, user PZUintelamt
Ajith_I_Intel
I wanted to let you know that we are looking into your issue and hope to get back to you soon.
Ajith_I_Intel
After reviewing the log messages, this error may have few reasons:
  1. User doesn't have permissions. You have mentioned earlier that theuser has domain admin rights, so this is probably not the cause of the issue,
  2. User didn't specify correct OU path in the configuration parameters. The user need to create a new OU on the AD(do not use built-in OUs) and choose this OU by clicking the '...' button left to the third textbox name Active Directory Organizational Unit'.
  3. Make sure that the OU name and the host name of the AMT are not the same.
Please note that from the log attached we don't see any provisioning attempt. If the above solution does not help, please send us the SCS log of the SCS console (turning on verbose log level) exported to a file (after provisioning attempt).
Anonymous3
This is a part of a log file with a provisioning attempt:
2007.08.06,12:33:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3944,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,12:34:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,12:34:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3920,SOURCE=.ADInterfaceADInterface.cpp,LINE=495,
Checking DS Object Existence at: "L"
2007.08.06,12:34:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3920,SOURCE=.ADInterfaceADInterface.cpp,LINE=518,
Object Does not Exists at: "L"
2007.08.06,12:34:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3920,SOURCE=.ADInterfaceADInterface.cpp,LINE=328,
Opening DS at: "L"
2007.08.06,12:34:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3920,SOURCE=.ADInterfaceADInterface.cpp,LINE=355,
Creating DS Object: "C"
2007.08.06,12:34:41,E,SERVER=1,USER=PZUintelamt,THREAD=3920,SOURCE=.WorkersCreateAdAmtObjectWorker.cpp,LINE=69,
Cannot create AD AMT Object: Failed on CreateDSObject with actina1a (-2147016649). - Process delayed.
2007.08.06,12:38:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,12:38:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=1464,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,12:38:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=1464,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,12:38:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
to get request d ata: pop
2007.08.06,12:38:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=2660,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,12:38:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3864,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,12:43:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,12:43:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=2460,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,12:43:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=2460,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,12:43:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,12:43:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5064,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,12:43:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=2568,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,12:48:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,12:48:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=1924,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,12:48:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=1924,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,12:48:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
to g et request data: pop
2007.08.06,12:48:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5092,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,12:48:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5812,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
Anonymous3
akillendula:
Checked
Checked
Checked
No effects :|
Ajith_I_Intel
We would like to get the following info from you:
The name of OU, user/domain name the SCS server is running with
And dev log.
Also we have made a refresh to our SCS 3.1 distribution, please check out this url to see if it affects you -
http://softwareblogs.intel.com/2007/08/07/a-quick-update-on-the-intelr-scs-31/. Updated version of SCS 3.1 can be found at http://software.intel.com/en-us/articles/download-the-latest-version-of-intel-amt-setup-and-configuration-service-scs.
Anonymous3
OU: OU=test,OU=SUS,OU=KOMPUTERY,OU=Centrala,DC=pzu,DC=pl
user/domain: intelamt/PZU
server name: fs2-centrala.pzu.pl
ver.: 3.1.0.7
Anonymous3
scs_server.log
2007.08.07,08:22:33,WARNING,SERVER=1,USER=(null)(null),THREAD=5940,SOURCE=......CommonscsObjectsUserRoleExtended.cpp,LINE=122,
role is null or empty
2007.08.07,08:22:33,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.Login.cpp,LINE=20,
Enter Authentication__Login
2007.08.07,08:22:33,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.Login.cpp,LINE=51,
Exit OK Authentication__Login
2007.08.07,08:22:33,INFORMATIONAL,SERVER=1,USER=(null)(null),THREAD=5940,SOURCE=......CommongeneralLogger.cpp,LINE=50,
2007.08.07,08:22:37,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=20,
Enter Profile__GetServiceProfiles
2007.08.07,08:22:37,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=26,
rows returned: 1
2007.08.07,08:22:37,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=34,
Loop 0
2007.08.07,08:22:37,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=44,
Default profile, ignore
Loop 1
2007.08.07,08:22:37,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=50,
Profile 1, 2
2007.08.07,08:22:37,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=53,
Profile name 1, CEN
2007.08.07,08:22:37,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=56,
Profile description 1, Default profile
2007.08.07,08:22:37,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=61,
There are 1 AMTs under profile 2
2007.08.07,08:22:37,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=66,
Finish OK get profiles
2007.08.07,08:22:39,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=22,
Enter Service__GetServiceNewAMTProperties
2007.08.07,08:22:39,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=29,
Params for list: where , order , from 0, size 15
2007.08.07,08:22:39,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=34,
returned 1 rows
2007.08.07,08:22:39,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=61,
Exit OK Service__GetServiceNewAMTProperties
2007.08.07,08:22:43,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=20,
2007.08.07,08:22:43,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=26,
rows returned: 1
2007.08.07,08:22:43,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=34,
Loop 0
2007.08.07,08:22:43,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp, LINE=44,
Loop 1
2007.08.07,08:22:43,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=50,
Profile 1, 2
2007.08.07,08:22:43,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=53,
Profile name 1, CEN
2007.08.07,08:22:43,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=56,
2007.08.07,08:22:43,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=61,
2007.08.07,08:22:43,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=66,
2007.08.07,08:23:26,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.SetServiceNewAMTProperties.cpp,LINE=26,
Enter Service__SetServiceNewAMTProperties
2007.08.07,08:23:26,INFORMATIONAL,SERVER=1,USER=(null)(null),THREAD=2456,SOURCE=.ServiceUtils.cpp,LINE=1872,
2007.08.07,08:23:26,ERROR,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.SetServiceNewAMTProperties.cpp,LINE=112,
Execution error -805370151: The specified Active Directory Organizational Unit OU=IntelTest,OU=SUS,OU=KOMPUTERY,OU=Centrala,DC=pzu,DC=pl not found.
2007.08.07,08:24:04,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=20,
2007.08.07,08:24:04,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=26,
rows returned: 1
2007.08.07,08:24:04,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=34,
Loop 0
2007.08.07,08:24:04,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=44,
Loop 1
2007.08.07,08:24:04,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=50,
Profile 1, 2
2007.08.07,08:24:04,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=53,
Profile name 1, CEN
2007.08.07,08:24:04,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=56,
2007.08.07,08:24:04,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=61,
2007.08.07,08:24:04,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=66,
2007.08.07,08:24:06,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetProfileGeneralParams.cpp,LINE=20,
Enter Profile__GetProfileGeneralParams
2007.08.07,08:24:06,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetProfileGeneralParams.cpp,LINE=33,
read profile 2
2007.08.07,08:24:06,INFORMATIONAL,SERVE R=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetProfileGeneralParams.cpp,LINE=43,
profile CEN, Default profile
2007.08.07,08:24:06,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetProfileGeneralParams.cpp,LINE=44,
Exit OK Profile__GetProfileGeneralParams
2007.08.07,08:24:06,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetProfileAdminUserAndPasswordEx.cpp,LINE=14,
Enter Profile__GetProfileAdminUserAndPassword
2007.08.07,08:24:06,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetProfileAdminUserAndPasswordEx.cpp,LINE=38,
Exit OK Profile__GetProfileAdminUserAndPassword
2007.08.07,08:24:06,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetProfileKerberosParams.cpp,LINE=21,
Enter Profile__GetProfileKerberosParams
2007.08.07,08:24:06,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetProfileKerberosParams.cpp,LINE=40,
Exit OK Profile__GetProfileKerberosParams
2007.08.07,08:24:09,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfileNetwork.cpp,LINE=20,
Enter Profile__GetServiceProfileNetwork
2007.08.07,08:24:09,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfileNetwork.cpp,LINE=36,
Vlan disabled
2007.08.07,08:24:09,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfileNetwork.cpp,LINE=41,
Enable Ping true
2007.08.07,08:24:09,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfileNetwork.cpp,LINE=61,
Web UI
2007.08.07,08:24:09,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfileNetwork.cpp,LINE=66,
Serial Over Lan
2007.08.07,08:24:09,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfileNetwork.cpp,LINE=71,
Ide Redirection
2007.08.07,08:24:09,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfileNetwork.cpp,LINE=75,
Exit OK Profile__GetServiceProfileNetwork
2007.08.07,08:24:09,INFORMATIONAL,SERVER=1,USER=(null)(null),THREAD=560,SOURCE=.GetProfileTLSOption.cpp,LINE=20,
Enter Profile__GetProfileTLSOption
2007.08.07,08:24:09,INFORMATIONAL,SERVER=1,USER=(null)(null),THREAD=560,SOURCE=.GetProfileTLSOption.cpp,LINE=43,
Exit OK Profile__GetProfileTLSOption
2007.08.07,08:24:09,INFORMATIONAL,SERVER=1,USER=(null)(null),THREAD=560,SOURCE=.GetProfileTLSServerCertificate.cpp,LINE=18,
Enter Profile__GetProfileTLSServerCertificate
2007.08.07,08:24:09,INFORMATIONAL,SERVER=1,USER=(null)(null),THREAD=560,SOURCE=.GetProfileTLSServerCertificate.cpp,LINE=58,
Exit OK Profile__GetProfileTLSServerCertificate
2007.08.07,08:24:10,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetProfileACL.cpp,LINE=21,
Enter Profile__GetProfileACL
2007.08.07,08:24:10,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetProfileACL.cpp,LINE=40,
Profile__GetProfileACL, num of acls: 1
2007.08.07,08:24:10,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetProfileACL.cpp,LINE=43,
Profile__GetProfileACL, start to fill acls...
2007.08.07,08:24:10,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetProfileACL.cpp,LINE=49,
Profile__GetProfileACL, acl 0
2007.08.07,08:24:10,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetProfileACL.cpp,LINE=79,
Profile__GetProfileACL, realms in acl 0: 13
2007.08.07,08:24:10,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetProfileACL.cpp,LINE=93,
Exit OK Profile__GetProfileACL
2007.08.07,08:24:14,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetProfilePowerPolicy.cpp,LINE=20,
Enter Profile__GetProfilePowerPolicy
2007.08.07,08:24:14,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetProfilePowerPolicy.cpp,LINE=42,
Exit OK Profile__GetProfilePowerPolicy
2007.08.07,08:24:15,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceGlobalParameters.cpp,LINE=20,
Enter Service__GetServiceGlobalParameters, user PZUKRZYS
2007.08.07,08:24:15,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceGlobalParameters.cpp,LINE=53,
Exit OK Service__GetServiceGlobalParameters
2007.08.07,08:24:15,INFORMATIONAL,SERVER=1,USER=(null)(null),THREAD=5940,SOURCE=.GetProfileWired8021xProfiles.cpp,LINE=19,
Enter Profile__GetProfileWired8021xProfiles
2007.08.07,08:24:15,INFORMATIONAL,SERVER=1,USER=(null)(null),THREAD=5940,SOURCE=.GetProfileWired8021xProfiles.cpp,LINE=70,
Exit OK Profile__GetProfileWired8021xProfiles
2007.08.07,08:24:15,INFORMATIONAL,SERVER=1,USER=(null)(null),THREAD=5940,SOURCE=.GetService8021xProfile.cpp,LINE=19,
Enter Service__GetService8021xProfile
2007.08.07,08:24:15,INFORMATIONAL,SERVER=1,USER=(null)(null),THREAD=5940,SOURCE=.GetService8021xProfile.cpp,LINE=111,
Exit OK Service__GetService8021xProfile
2007.08.07,08:24:16,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=20,
2007.08.07,08:24:16,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=26,
rows returned: 1
2007.08.07,08:24:16,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=34,
Loop 0
2007.08.07,08:24:16,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=44,
Loop 1
2007.08.07,08:24:16,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=50,
Profile 1, 2
2007.08.07,08:24:16,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=53,
Profile name 1, CEN
2007.08.07,08:24:16,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=56,
2007.08.07,08:24:16,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=61,
2007.08.07,08:24:16,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=66,
2007.08.07,08:24:18,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=22,
E nter Service__GetServiceNewAMTProperties
2007.08.07,08:24:18,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=29,
2007.08.07,08:24:18,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=34,
returned 1 rows
2007.08.07,08:24:18,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=61,
2007.08.07,08:24:20,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetAMTList.cpp,LINE=22,
Enter Amt__GetAMTList
2007.08.07,08:24:20,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetAMTList.cpp,LINE=29,
2007.08.07,08:24:20,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetAMTList.cpp,LINE=34,
returned 1 rows
2007.08.07,08:24:20,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetAMTList.cpp,LINE=107,
Exit OK Amt__GetAMTList
2007.08.07,08:24:24,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetAMTConfiguration.cpp,LINE=23,
Enter Amt__GetAMTConfiguration
2007.08.07,08:24:24,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetAMTConfiguration.cpp,LINE=77,
Exit OK Amt__GetAMTConfiguration
2007.08.07,08:24:26,INFORMATIONAL,SERVER=1,USER=(null)(null),THREAD=560,SOURCE=.GetAMTMaintananceInfo.cpp,LINE=25,
Enter Amt__GetAMTStatus
2007.08.07,08:24:26,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetAMTMaintananceInfo.cpp,LINE=70,
Amt__GetAMTStatus, got 0 status entries
2007.08.07,08:24:26,INFORMATIONAL,SERVER=1,USER=(null)(null),THREAD=560,SOURCE=.GetAMTMaintananceInfo.cpp,LINE=99,
Exit OK Amt__GetAMTStatus
2007.08.07,08:24:28,INFORMATIONAL,SERVER=1,USER=(null)(null),THREAD=560,SOURCE=.GetServiceZTCConfiguration.cpp,LINE=19,
Enter Service__GetServiceZTCConfiguration
2007.08.07,08:24:28,INFORMATIONAL,SERVER=1,USER=(null)(null),THREAD=560,SOURCE=.GetServiceZTCConfiguration.cpp,LINE=23,
Exit OK Service__GetServiceZTCConfiguration
2007.08.07,08:24:28,INFORMATIONAL,SERVER=1,USER=(null)(null),THREAD=5940,SOURCE=.GetServicePAMConfiguration.cpp,LINE=19,
Enter Service__GetServicePAMConfiguration
2007.08.07,08:24:28,INFORMATIONAL,SERVER=1,USER=(null)(null),THREAD=5940,SOURCE=.GetServicePAMConfiguration.cpp,LINE=31,
Exit OK Service__GetServicePAMConfiguration
2007.08.07,08:24:29,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetAMTList.cpp,LINE=22,
2007.08.07,08:24:29,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetAMTList.cpp,LINE=29,
2007.08.07,08:24:29,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetAMTList.cpp,LINE=34,
returned 1 rows
2007.08.07,08:24:29,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetAMTList.cpp,LINE=107,
2007.08.07,08:24:31,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=22,
Enter S ervice__GetServiceNewAMTProperties
2007.08.07,08:24:31,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=29,
2007.08.07,08:24:31,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=34,
returned 1 rows
2007.08.07,08:24:31,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=61,
2007.08.07,08:24:34,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceProfiles.cpp,LINE=20,
2007.08.07,08:24:34,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceProfiles.cpp,LINE=26,
rows returned: 1
2007.08.07,08:24:34,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceProfiles.cpp,LINE=34,
Loop 0
2007.08.07,08:24:34,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceProfiles.cpp,LINE=44,
Loop 1
2007.08.07,08:24:34,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceProfiles.cpp,LINE=50,
Profile 1, 2
2007.08.07,08:24:34,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceProfiles.cpp,LINE=53,
Profile name 1, CEN
2007.08.07,08:24:34,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceProfiles.cpp,LINE=56,
2007.08.07,08:24:34,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceProfiles.cpp,LINE=61,
2007.08.07,08:24:34,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceProfiles.cpp,LINE=66,
2007.08.07,08:24:50,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=20,
2007.08.07,08:24:50,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=26,
rows returned: 1
2007.08.07,08:24:50,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=34,
Loop 0
2007.08.07,08:24:50,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=44,
Loop 1
2007.08.07,08:24:50,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=50,
Profile 1, 2
2007.08.07,08:24:50,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=53,
Profile name 1, CEN
2007.08.07,08:24:50,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=56,
2007.08.07,08:24:50,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=61,
2007.08.07,08: 24:50,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=66,
2007.08.07,08:31:04,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=20,
2007.08.07,08:31:04,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=26,
rows returned: 1
2007.08.07,08:31:04,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=34,
Loop 0
2007.08.07,08:31:04,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=44,
Loop 1
2007.08.07,08:31:04,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=50,
Profile 1, 2
2007.08.07,08:31:04,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=53,
Profile name 1, CEN
2007.08.07,08:31:04,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=56,
2007.08.07,08:31:04,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=61,
2007.08.07,08:31:04,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceProfiles.cpp,LINE=66,
2007.08.07,08:31:10,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.SetServiceNewAMTProperties.cpp,LINE=26,
2007.08.07,08:31:10,INFORMATIONAL,SERVER=1,USER=(null)(null),THREAD=560,SOURCE=.ServiceUtils.cpp,LINE=1872,
2007.08.07,08:31:11,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.SetServiceNewAMTProperties.cpp,LINE=105,
Exit OK Service__SetServiceNewAMTProperties
2007.08.07,08:31:11,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=22,
2007.08.07,08:31:11,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=29,
2007.08.07,08:31:11,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=34,
returned 1 rows
2007.08.07,08:31:11,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=61,
2007.08.07,08:31:12,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=20,
2007.08.07,08:31:12,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=26,
rows returned: 1
2007.08.07,08:31:12,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=34,
Loop 0
2007.08.07,08:31:12,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=44,
Default profil e, ignore
Loop 1
2007.08.07,08:31:12,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=50,
Profile 1, 2
2007.08.07,08:31:12,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=53,
Profile name 1, CEN
2007.08.07,08:31:12,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=56,
2007.08.07,08:31:12,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=61,
2007.08.07,08:31:12,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=66,
2007.08.07,08:31:47,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.SetServiceNewAMTProperties.cpp,LINE=26,
2007.08.07,08:31:47,INFORMATIONAL,SERVER=1,USER=(null)(null),THREAD=2456,SOURCE=.ServiceUtils.cpp,LINE=1872,
2007.08.07,08:31:47,ERROR,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.SetServiceNewAMTProperties.cpp,LINE=112,
Execution error -805370151: The specified Active Directory Organizational Unit CN=actina1a,OU=Intel,OU=test,OU=SUS,OU=KOMPUTERY,OU=Centrala,DC=pzu,DC=pl not found.
2007.08.07,09:05:05,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=20,
2007.08.07,09:05:05,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=26,
rows returned: 1
2007.08.07,09:05:05,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=34,
Loop 0
2007.08.07,09:05:06,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=44,
2007.08.07,09:05:06,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=34,
Loop 1
2007.08.07,09:05:06,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=50,
Profile 1, 2
2007.08.07,09:05:06,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=53,
Profile name 1, CEN
2007.08.07,09:05:06,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=56,
2007.08.07,09:05:06,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=61,
2007.08.07,09:05:06,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=66,
2007.08.07,09:05:35,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetAMTList.cpp,LINE=22,
2007.08.07,09:05:35,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetAMTList.cpp,LINE=29,
2007.08.07,09:05:35,INFORMATIONAL,SERVER=1,USE R=PZUKRZYS,THREAD=2456,SOURCE=.GetAMTList.cpp,LINE=34,
returned 1 rows
2007.08.07,09:05:35,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetAMTList.cpp,LINE=107,
2007.08.07,09:05:36,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetAMTList.cpp,LINE=22,
2007.08.07,09:05:36,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetAMTList.cpp,LINE=29,
2007.08.07,09:05:36,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetAMTList.cpp,LINE=34,
returned 1 rows
2007.08.07,09:05:36,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetAMTList.cpp,LINE=107,
2007.08.07,09:05:46,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=21,
Enter Service__GetServiceLog
2007.08.07,09:05:46,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=27,
Params for list: where where (is_security = 0) and (uuid like 'C43AB188BCD2DB11911D00E018BFD7DC'), order order by insert_time desc, from 0, size 15
2007.08.07,09:05:46,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:05:46,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=58,
Exit OK Service__GetServiceLog
2007.08.07,09:05:52,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=22,
2007.08.07,09:05:52,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=29,
2007.08.07,09:05:52,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=34,
returned 1 rows
2007.08.07,09:05:53,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=61,
2007.08.07,09:05:56,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=20,
2007.08.07,09:05:56,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=26,
rows returned: 1
2007.08.07,09:05:56,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=34,
Loop 0
2007.08.07,09:05:56,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=44,
Loop 1
2007.08.07,09:05:56,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=50,
Profile 1, 2
2007.08.07,09:05:56,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=53,
Profile name 1, CEN
2007.08.07,09:05:56,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=56,
2007.08.07,09:05:56,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=61,
2007.08.07,09:05:56,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceProfiles.cpp,LINE=66,
2007.08.07,09:06:17,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.SetServiceNewAMTProperties.cpp,LINE=26,
2007.08.07,09:06:18,INFORMATIONAL,SERVER=1,USER=(null)(null),THREAD=560,SOURCE=.ServiceUtils.cpp,LINE=1872,
2007.08.07,09:06:18,ERROR,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.SetServiceNewAMTProperties.cpp,LINE=112,
Execution error -805370151: The specified Active Directory Organizational Unit CN=actina1a,OU=IntelTest,OU=test,OU=SUS,OU=KOMPUTERY,OU=Centrala,DC=pzu,DC=pl not found.
2007.08.07,09:08:32,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.SetServiceNewAMTProperties.cpp,LINE=26,
2007.08.07,09:08:32,INFORMATIONAL,SERVER=1,USER=(null)(null),THREAD=2456,SOURCE=.ServiceUtils.cpp,LINE=1872,
2007.08.07,09:08:32,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.SetServiceNewAMTProperties.cpp,LINE=105,
2007.08.07,09:08:32,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=22,
2007.08.07,09:08:32,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=29,
2007.08.07,09:08:32,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=34,
returned 1 rows
2007.08.07,09:08:32,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=61,
2007.08.07,09:08:38,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=22,
2007.08.07,09:08:38,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=29,
2007.08.07,09:08:38,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=34,
returned 1 rows
2007.08.07,09:08:38,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=61,
2007.08.07,09:08:38,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=22,
2007.08.07,09:08:38,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=29,
2007.08.07,09:08:38,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=34,
returned 1 rows
2007.08.07,09:08:38,INFORMATIONAL,SERVER =1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=61,
2007.08.07,09:08:39,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=22,
2007.08.07,09:08:39,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=29,
2007.08.07,09:08:39,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=34,
returned 1 rows
2007.08.07,09:08:39,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceNewAMTProperties.cpp,LINE=61,
2007.08.07,09:08:40,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:08:40,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=27,
Params for list: where where (is_security = 0), order order by insert_time desc, from 0, size 15
2007.08.07,09:08:40,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:08:40,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:08:43,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetAMTList.cpp,LINE=22,
2007.08.07,09:08:43,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetAMTList.cpp,LINE=29,
2007.08.07,09:08:43,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetAMTList.cpp,LINE=34,
returned 1 rows
2007.08.07,09:08:43,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetAMTList.cpp,LINE=107,
2007.08.07,09:08:44,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetAMTList.cpp,LINE=22,
2007.08.07,09:08:44,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetAMTList.cpp,LINE=29,
2007.08.07,09:08:44,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetAMTList.cpp,LINE=34,
returned 1 rows
2007.08.07,09:08:44,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetAMTList.cpp,LINE=107,
2007.08.07,09:08:46,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetAMTList.cpp,LINE=22,
2007.08.07,09:08:46,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetAMTList.cpp,LINE=29,
2007.08.07,09:08:46,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetAMTList.cpp,LINE=34,
returned 1 rows
2007.08.07,09:08:46,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetAMTList.cpp,LINE=107,
2007.08.07,09:08:47,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetAMTList.cpp,LINE=22,
2 007.08.07,09:08:47,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetAMTList.cpp,LINE=29,
2007.08.07,09:08:47,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetAMTList.cpp,LINE=34,
returned 1 rows
2007.08.07,09:08:47,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetAMTList.cpp,LINE=107,
2007.08.07,09:08:47,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetAMTList.cpp,LINE=22,
2007.08.07,09:08:47,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetAMTList.cpp,LINE=29,
2007.08.07,09:08:47,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetAMTList.cpp,LINE=34,
returned 1 rows
2007.08.07,09:08:47,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetAMTList.cpp,LINE=107,
2007.08.07,09:08:47,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetAMTList.cpp,LINE=22,
2007.08.07,09:08:47,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetAMTList.cpp,LINE=29,
2007.08.07,09:08:47,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetAMTList.cpp,LINE=34,
returned 1 rows
2007.08.07,09:08:47,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetAMTList.cpp,LINE=107,
returned 1 rows
returned 1 rows
returned 1 rows
2007.08 .07,09:08:48,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetAMTList.cpp,LINE=22,
2007.08.07,09:08:48,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetAMTList.cpp,LINE=29,
2007.08.07,09:08:48,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetAMTList.cpp,LINE=34,
returned 1 rows
2007.08.07,09:08:48,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetAMTList.cpp,LINE=107,
2007.08.07,09:08:49,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:08:49,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:08:49,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:08:49,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:08:51,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:08:51,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:08:51,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:08:51,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=58,
returned 15 rows
2007.08.07,09:08:51,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:08:51,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:08:51,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:08:51,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:08:51,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:08:51,INF ORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:08:51,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:08:51,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceLog.cpp,LINE=58,
returned 15 rows
2007.08.07,09:08:52,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:08:52,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:08:52,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:08:52,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:08:52,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:08:52,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:08:52,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:08:52,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=58,
returned 15 rows
returned 15 rows
returned 15 rows
2007.08.07,09:08:53,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:09:47,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:09:47,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:09:47,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:09:47,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:09:48,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:09:48,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:09:48,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:09:48,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:09:49,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:09:49,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:09:49,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:09:49,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:09:49,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:09:49,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=27,
< BR>2007.08.07,09:09:49,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:09:49,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:09:50,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:09:50,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:09:50,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:09:50,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:09:53,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:09:53,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:09:53,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:09:53,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:09:53,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:09:53,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:09:53,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:09:53,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:09:54,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:09:54,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:09:54,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:09:54,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:09:55,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:09:55,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:09:55,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp, LINE=31,
returned 15 rows
2007.08.07,09:09:55,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:10:09,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:10:09,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:10:09,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:10:09,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:10:09,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:10:09,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:10:09,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:10:09,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:10:10,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:10:10,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:10:10,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:10:10,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:10:10,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:10:10,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:10:10,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:10:10,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:10:11,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:10:11,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:10:11,INFORMATIONAL,SERVER=1,USER=PZUKR ZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:10:11,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:10:11,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:10:11,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:10:11,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:10:12,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:10:12,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:10:12,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:10:12,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=58,
returned 15 rows
2007.08.07,09:10:12,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:10:12,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:10:12,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:10:12,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:10:13,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:10:13,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:10:13,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:10:13,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:10:13,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:10:13,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:10:13,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:10:13,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=58,
returned 15 rows
2007.08.07,09:10:14,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:10:14,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:10:14,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:10:14,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=5940,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:10:14,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:10:14,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:10:14,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:10:14,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=560,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:10:14,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=21,
2007.08.07,09:10:14,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=27,
2007.08.07,09:10:14,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=31,
returned 15 rows
2007.08.07,09:10:14,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=58,
2007.08.07,09:10:15,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog. cpp,LINE=21,
2007.08.07,09:10:15,INFORMATIONAL,SERVER=1,USER=PZUKRZYS,THREAD=2456,SOURCE=.GetServiceLog.cpp,LINE=27,
Anonymous3
part of scs_win_server.log
Server stopped.
Server stopped.
Starting server
Checking user....
2007.08.06,12:18:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5912,SOURCE=.mai nConfigurationServer.cpp,LINE=27,
2007.08.0 6,12:18:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=428,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,12:23:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,12:23:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5552,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,12:23:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5552,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,12:23:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,12:23:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4616,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,12:23:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=2248,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,12:28:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,12:28:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4492,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,12:28:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4492,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,12:28:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.0 6,12:28:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4732,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,12:28:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4536,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,12:33:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,12:33:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3848,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,12:33:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3848,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,12:33:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,12:33:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3884,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,12:34:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3920,SO URCE=.ADInterfaceADInterface.cpp,LINE=328,
Opening DS at: "L"
2007.08.06,12:43:43,INFORMATIONAL,SERV ER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,12:53:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,12:53:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4632,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,12:53:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4632,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
Maintenance worker pushes request for command_id=18 and uuid=&n bsp;
2007.08.06,12:53:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,12:53:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4328,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,12:53:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5496,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,12:58:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,12:58:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=2460,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,12:58:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=2460,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,12:58:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=2460,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,12:58:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,12:58:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5972,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,12:58:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=1800,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,13:03:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,13:03:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3888,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,13:03:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3888,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,13:03:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3888,SOURC E=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,13:03:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,13:03:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3844,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,13:03:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3396,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,13:08:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,13:08:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=1672,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,13:08:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=1672,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,13:08:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,13:08:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=2132,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,13:08:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5372,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,13:13:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,13:13:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3612,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,13:13:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3612,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,13:13:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,13:13:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5980,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,13:13:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5136,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,13:18:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,13:18:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=1748,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,13:18:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=1748,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,13:18:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,13:18:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5744,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,13:18:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4104,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,13:23:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,13:23:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=1924,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,13:23:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=1924,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=1 12,
2007.08.06,13:23:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=1924,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,13:23:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,13:23:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=2756,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,13:23:45,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=6120,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,13:28:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,13:28:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5196,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,13:28:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5196,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,13:28:45,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,13:28:45,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5440,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,13:28:45,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=1108,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,13:33:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,13:33:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=6124,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
&nbs p;Enter Maintenance worker, user PZUintelamt
2007.08.06,13:33:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=6124,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,13:33:45,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,13:33:45,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5112,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,13:33:45,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5872,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,13:35:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,13:35:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=2472,SOURCE=.ADInterfaceADInterface.cpp,LINE=495,
2007.08.06,13:35:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=2472,SOURCE=.ADInterfaceADInterface.cpp,LINE=518,
2007.08.06,13:35:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=2472,SOURCE=.ADInterfaceADInterface.cpp,LINE=328,
Opening DS at: "L"
2007.08.06,13:35:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=2472,SOURCE=.ADInterfaceADInterface.cpp,LINE=355,
2007.08.06,13:35:42,E,SERVER=1,USER=PZUintelamt,THREAD=2472,SOURCE=.WorkersCreateAdAmtObjectWorker.cpp,LINE=69,
2007.08.06,13:38:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007. 08.06,13:38:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=788,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,13:38:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=788,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,13:38:45,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,13:38:45,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5376,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,13:38:45,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=2404,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,13:43:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,13:43:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=2656,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,13:43:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=2656,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,13:43:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,13:43:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4624,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,13:43:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3140,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,13:48:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,13:48:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5732,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,13:48:43,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5732,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,13:48:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
to get request data: pop
2007.08.06,13:48:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4948,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,13:48:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=404,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,13:53:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,13:53:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=6104,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,13:53:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=6104,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
Maintenance worker pushes request for command_id=17 and uuid=
2007.08.06,13:53:45,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,13:53:45,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4488,SOURCE=.WorkersCleanLog.cpp,LINE=15,
Enter Clean log worker, user PZUintelamt
2007.08.06,13:53:45,IN FORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=720,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
Enter Clean status of requests worker, user PZUintelamt
2007.08.06,13:58:45,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,13:58:45,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5732,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,13:58:45,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5732,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,13:58:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,13:58:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=844,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,13:58:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4356,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,14:03:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,14:03:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3772,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,14:03:44,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3772,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,14:03:45,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,14:03:45,INF ORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5436,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,14:03:45,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5012,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,14:08:45,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,14:08:45,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=1984,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,14:08:45,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=1984,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,14:08:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,14:08:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=656,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,14:08:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5872,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,14:13:45,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,14:13:45,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4148,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,14:13:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4148,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,14:13:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,1 4:13:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,14:13:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=284,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,14:13:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5016,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,14:18:45,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,14:18:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=6072,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,14:18:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=6072,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,14:18:47,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,14:18:47,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4156,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,14:18:47,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=1972,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,14:23:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,14:23:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=1672,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,14:23:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=1672,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2 007.08.06,14:23:47,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,14:23:47,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,14:23:47,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5580,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,14:23:47,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5924,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,14:28:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,14:28:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=844,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,14:28:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=844,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,14:28:47,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,14:28:47,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=396,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,14:28:47,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5408,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,14:33:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,14:33:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4536,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,14:33:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4536,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
Maintenance worker pushes request for command_id=18 and uuid=  ;
2007.08.06,14:33:47,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,14:33:47,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5800,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,14:33:47,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5948,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,14:36:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,14:36:41,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3396,SOURCE=.ADInterfaceADInterface.cpp,LINE=495,
Checking DS Object Existence at: "L"
2007.08.06,14:36:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3396,SOURCE=.ADInterfaceADInterface.cpp,LINE=518,
Object Does not Exists at: "L"
2007.08.06,14:36:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3396,SOURCE=.ADInterfaceADInterface.cpp,LINE=495,
2007.08.06,14:36:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3396,SOURCE=.ADInterfaceADInterface.cpp,LINE=328,
Opening DS at: "L"
2007.08.06,14:36:42,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=3396,SOURCE=.ADInterfaceADInterface.cpp,LINE=355,
Creating DS Object: "C"
2007.08.06,14:36:42,E,SERVER=1,USER=PZUintelamt,THREAD=3396,SOURCE=.WorkersCreateAdAmtObjectWorker.cpp,LINE=69,
Cannot create AD AMT Object: Failed on CreateDSObject with actina1a (-2147016649). - Process delayed.
2007.08.06,14:38:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,14:38:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=960,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,14:38:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=960,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,14:38:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=960,SOURCE=.WorkersMaintenance Worker.cpp,LINE=112,
2007.08.06,14:38:47,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,14:38:47,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=1932,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,14:38:47,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5480,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,14:43:47,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,14:43:47,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4944,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,14:43:47,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4944,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.08.06,14:43:48,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,14:43:48,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5440,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.08.06,14:43:48,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=5968,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.08.06,14:48:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4940,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.08.06,14:48:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4496,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.08.06,14:48:46,INFORMATIONAL,SERVER=1,USER=PZUintelamt,THREAD=4496,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
Maintenance worker pushes request for command_id=17 and uuid=  ;
Ajith_I_Intel
Thanks for the information. Wehope toget back to you shortly.
Ajith_I_Intel
Hi There,
The dev log is different from service log.
In order to create dev log you need to Define key: HKEY_LOCAL_MACHINE->SOTWARE->Intel->AMTConfServer->LOG then LogLevel key with string value V.
The dev log will be created in the root directory.
Regarding OU for AMT objects:
It should be created in the root and not under other OU.
Please try changing the OU to under root. If you still encounter problems, send us the dev log file.
Anonymous3
Hi again,
I defined that key and i've got scs_server.log and scs_win_server.log files only in the root dir.
Ajith_I_Intel
Can you attach the scs_win_server.txt file? Instead of attaching a portion of the file, we would like the whole file attached.
Anonymous3
The scs_win_server.txt file is too big to attach to the forum :|
vzvezda
Had the same SCS error and this was helpful for me:
  1. User didn't specify correct OU path in the configuration parameters. The user need to create a new OU on the AD(do not use built-in OUs) and choose this OU by clicking the '...' button left to the third textbox name Active Directory Organizational Unit'.
  2. Make sure that the OU name and the host name of the AMT are not the same.
Thanks!
