Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
Secure SOL not woking with Commander
sohaib2y
Hi all,
TSL based SOL is not working with AMT Commander, When I press take control, it starts the Terminal Tool (console window) but nothing appears there, I select "Remote Reboot to Bios Setup" option from menu, the AMT machine boots and enters BIOS, but nothing apperas on the AMT Terminal Tool (Console window).
I think TLS is working fine, because when I had TLS problem, it was not even taking control and was showing error on "Take Control" button.
It worked before in Small Business mode.
Any clue.
Sohaib
sohaib2y
I tried again and again with commander, finally it worked, my be I powered AMT down and rebooted, don't know exactly what resolved it...but now its working
Sohaib
Ylian_S_Intel
This is weird, but I do let you disconnect and connect to SOL in the terminal menu and I have found that, since the redirect library does not give me good status of what is going on, it may lose connection and Commander will not know. As for TLS, I have many lots of efforts to have Commnader connect with warnings when something goes wrong with certificate validation. This is important since Commander can still connect to a computer with an invalid certificate, but the redirection library will refuse. Starting with version v0.32, I show connection warnings and gray out the "Take Control..." button.
Ylian (Intel AMT Blog)
