Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
problem with remote reset to bios
feyd
When I send command "remote reset to bios" to computer with motherboard Gigabyte 965QM-DS2 and bios Award Modular BIOS v6.00PG Release Date 19 January 2007. I get message NOT_PERMITTED. I also have a problem with DHCP, when Intel AMT is running with this mode, before system boting I receive message "iAMT is not configured".
Sreelekshm_S_Intel
Did you get into the MEBx and configured AMT? You could do this by hitting ctrl + P while the system is booting up. Also, please make sure that you have installed all the required drivers.
Sree
feyd
Yes, I configured AMT and it works well with all other command, but still i can not get remoting access to bios.
Sreelekshm_S_Intel
Just wanted to make sure that you have enabled SOL/IDE-R in MEBx. Are you able to boot to a remote CD/floppy image?
Sree
feyd
Yes, it works well, the only problem is remote to bios.
Sreelekshm_S_Intel
This seems to be an issue with SMS add on. Please go to this link below and click on the support link to submit your question:
http://software.intel.com/en-us/articles/intel-client-manageability-add-on-for-microsoft-sms-2003
Regarding the DHCP issue, are you able to connect to the AMT system through WebUI? You can do this by http://ipaddress:16992 . And after that, disconnect it and reboot the system. See if you are seeing the message again.
Sree
