Intel® C++ Compiler
7837 Discussions
1> warning #31001: The dll for reading and writing the pdb (for example, mspdb110.dll) could not be found on your path. This i
Michel_B_
I have a clean install of Windows 7, Visual Studio 2013 and Intel Parallel Studio XE 2013 SP 1 with all the available updates.
Compiling the following the program
#include <iostream>
int main(int ac, char* av[])
    std::cout << "Hello World!";
gives this error
1>  warning #31001: The dll for reading and writing the pdb (for example, mspdb110.dll) could  not be found on your path. This is usually a configuration error. Compilation will continue using /Z7 instead of /Zi, but expect a similar error when you link your program.
when having select to use the intel compiler by Project -> Intel Composer XE 2013 SP -> Use intel ... and after creating an x64 solution platform by going to configuration manager -> new -> x64 ( tried it both with and without copy of win32). I am at loss here, the win32 solution compiles without any problems, but would like to use the x64 platform.
Anyone an idea what is going wrong?
Ps. Merry Christmas!
JenniferJ
Try the workarounds in this article, and let me know if it helps.
Jennifer
JenniferJ
Jennifer
Michel_B_
Thanks Jennifer! That worked perfectly! Thank you so much !
Greg_S_3
I have been experiencing similar problems relative to warning (#31001) regarding reading and writing the pdb. Also I get an error when I try to open the article that Jennifer J referred to so I cannot see what the solution might have been.  I have read some of the articles that pertain to this issue but I can not seem to resolve this on my system
I was a user of the 11.0 version of the compilier but recently had to upgrade to 14.0 (Composer XE 2013 SP1).  After making several attempts with both packages installed I decided to remove the old version.  To do this I uninstalled both versions of the compilier as well as all versions of visual studio and any stub directories left over after the uninstall.  After all the uninstalls I shutdown and reinstalled only 14.0.  I do not have a standalone version of visual studio - just what was bundled with 14.  The version that I have only supports command line compile.  It is interesting that for visual studio I now have entries in my start menu for both Microsoft Visual Studio 2008 and Microsoft Visual Studio 2012 Express even though I had checked that I had removed any reference visual studio after the uninstalls.
When I use the "IA-32 Visual Studio 2012 mode - Windows" version of the command prompt with the -debug switch, everything seems to work properly.
When I use the "Intel 64 Visual Studio 2012 mode - Windows" vesion of the command prompt then I see this problem when I have the -debug switch in the command line:
Feilong_H_Intel
Greg,
There was a typo in the URL that Jennifer posted.  I fixed it a few seconds ago.  Please try to open it again.
