I'm compiling my application with -QxSSE -GL, since I have users that have non-SSE2 capable machines. I just got a minidump from such a user, and the compiler has issued a 'movsd xmm, mem' instruction. The subroutine deals only with floats, but does have some SSE intrinsics.
As far as I can tell, the code which causes the problems is:
mem[2] = _mm_setr_ps(_mem[8], _mem[9], 0, 0);
den[2] = _mm_setr_ps(_den[8], _den[9], 0, 0);
mem[] and den[] are __m128, while _mem and _den are float *.
The compiler cleverly restructures each line into a single movsd (for _mem[8], _mem[9]) followed by xorps (for the 0, 0) and movlhps (to merge the two). Problem is movsd is a SSE2 command, which -QxSSE should have disabled. As far as I can see, this is the only SSE2 command used.
If I remove '-GL', the problem goes away, but so does some of the performance, and the users non non-SSE2 capable processors are the ones that need the optimizations the most.
Is there a workaround I can apply to tell the compiler that SSE is ok, but SSE2 really isn't, no matter how fancy it is?
Apologies if this is fixed in 11.1.048; I keep getting linker errors about symbol files with that release, so I've had to stay on 11.0 for now.
Since ICL 11.0, the only option which doesn't generate SSE2 is /arch:ia32. 10.0 had a -QxK option for SSE, but it wasn't reliable in library support.
Quoting - tim18
Tim is right. Please use /arch:ia32.
do mean the .sbr file issue below? If so, it's being fixed as we speak.
BSCMAKE: error BK1506 : cannot open file 'C:Dev_build_intDSPTestRelDebugDspFilter.sbr': No such file or directory
Jennifer
Quoting - Jennifer Jiang (Intel)
Jennifer
No, in 11.1.048 I'm seeing
mumble_pch.obj : fatal error LNK1318: Unexpected PDB error; RPC (23) '(0x000006BA)'
The same code compiles without any problems using 11.0.075.. Apart from the unwanted SSE2 code, that is.
I can't use 10.1 for this, as that gives me missing vtable symbols in declspec(dllimport)ed C++ classes.
Right now it looks like I'll have to split out my performance critical code into a DLL, without any external C++ classes, compile that with 10.1 -QxK, and compile the rest with 11.0 with -arch:ia32 .. That is more than a little bit messy though, and I'd really like to avoid it if possible. Compiling all the code with -arch:ia32 isn't an option, as I need the vectorized speedup of the performance critical parts to be able to run in realtime on the non-SSE2 processors.
Quoting - thorvald.natvig
This issue was reported before but got fixed. I verified the original testcase, it is indeed fixed.
so this maybe caused by a different scenario. Is it possible for you to send me more info or a testcase?
Jennifer
Jennifer
I haven't been able to create any minimal testcase for this; it happens when I link my application, but doesn't happen on smaller tests.
I'll test some more and see if I can narrow it down a bit, and if so I'll post a followup here.
