I just installed 11.1.054 and code that worked fine with earlier versions (latest 11.0.075) now compiles ok in Release mode but fails in Debug mode. The errors are in the standard header files, not my own code. I'm not overriding any allocators or other parameters, just using defaults. Here are some sample errors:
c:\Program Files\Microsoft Visual Studio 9.0\VC\include\xdebug(75): error: a class or namespace qualified name is required
typedef typename _DebugHeapAllocator<_Other> other;
c:\Program Files\Microsoft Visual Studio 9.0\VC\include\xstring(502): error: name followed by "::" must be a class or namespace name
typedef typename _Alloc::size_type size_type;
detected during instantiation of class "std::basic_string<_Elem, _Traits, _Ax> [with _Elem=char, _Traits=std::char_traits, _Ax=std::_DebugHeapAllocator]" at line 110 of "c:\Program Files\Microsoft Visual Studio 9.0\VC\include\xdebug"
c:\Program Files\Microsoft Visual Studio 9.0\VC\include\xstring(503): error: name followed by "::" must be a class or namespace name
typedef typename _Alloc::difference_type _Dift;
Any ideas on what the problem is?
Ron
Ron
Quoting - rhylton
c:Program FilesMicrosoft Visual Studio 9.0VCincludexdebug(75): error: a class or namespace qualified name is required
c:Program FilesMicrosoft Visual Studio 9.0VCincludexstring(502): error: name followed by "::" must be a class or namespace name
detected during instantiation of class "std::basic_string<_Elem, _Traits, _Ax> [with _Elem=char, _Traits=std::char_traits, _Ax=std::_DebugHeapAllocator]" at line 110 of "c:Program FilesMicrosoft Visual Studio 9.0VCincludexdebug"
c:Program FilesMicrosoft Visual Studio 9.0VCincludexstring(503): error: name followed by "::" must be a class or namespace name
Ron
Ron
This could mean that you have some macro defined in a header that is included before
Judy
Quoting - Judith Ward (Intel)
Judy
The problem seems to have been caused by using /Qms0. After removing this the problem disappeared. I'm against putting bugs into the compiler, but being able to use headers like
