If I install ParallelStudio XE 2019.4 on a box running Amazon Linux in duplicate mode, I get the following output:
> sudo ./install.sh -d intel.config
> cat intel.config
ACCEPT_EULA=accept
CONTINUE_WITH_OPTIONAL_ERROR=yes
PSET_INSTALL_DIR=/opt/intel
CONTINUE_WITH_INSTALLDIR_OVERWRITE=yes
PSET_MODE=install
ACTIVATION_SERIAL_NUMBER=XXXXX-XXXXX
ACTIVATION_TYPE=serial_number
AMPLIFIER_SAMPLING_DRIVER_INSTALL_TYPE=build
AMPLIFIER_DRIVER_ACCESS_GROUP=vtune
AMPLIFIER_DRIVER_PERMISSIONS=666
AMPLIFIER_LOAD_DRIVER=no
AMPLIFIER_C_COMPILER=/usr/bin/gcc
AMPLIFIER_KERNEL_SRC_DIR=/lib/modules/4.14.133-88.105.amzn1.x86_64/build
AMPLIFIER_MAKE_COMMAND=/usr/bin/make
AMPLIFIER_INSTALL_BOOT_SCRIPT=no
AMPLIFIER_DRIVER_PER_USER_MODE=no
INTEL_SW_IMPROVEMENT_PROGRAM_CONSENT=no
ARCH_SELECTED=INTEL64
COMPONENTS=;intel-conda-index-tool__x86_64;intel-comp__x86_64;intel-comp-32bit__x86_64;intel-comp-doc__noarch;intel-comp-l-all-common__noarch;intel-comp-l-all-vars__noarch;intel-comp-nomcu-vars__noarch;intel-comp-ps-32bit__x86_64;intel-comp-ps__x86_64;intel-comp-ps-ss__x86_64;intel-comp-ps-ss-bec__x86_64;intel-comp-ps-ss-bec-32bit__x86_64;intel-openmp__x86_64;intel-openmp-32bit__x86_64;intel-openmp-common__noarch;intel-openmp-common-icc__noarch;intel-openmp-common-ifort__noarch;intel-openmp-ifort__x86_64;intel-openmp-ifort-32bit__x86_64;intel-tbb-libs-32bit__x86_64;intel-tbb-libs__x86_64;intel-idesupport-icc-common-ps__noarch;intel-conda-intel-openmp-linux-64-shadow-package__x86_64;intel-conda-intel-openmp-linux-32-shadow-package__x86_64;intel-conda-icc_rt-linux-64-shadow-package__x86_64;intel-icc__x86_64;intel-c-comp-common__noarch;intel-icc-common__noarch;intel-icc-common-ps__noarch;intel-icc-common-ps-ss-bec__noarch;intel-icc-doc__noarch;intel-icc-doc-ps__noarch;intel-icc-ps__x86_64;intel-icc-ps-ss-bec__x86_64;intel-ifort__x86_64;intel-ifort-common__noarch;intel-ifort-doc__noarch;intel-mkl-common__noarch;intel-mkl-core__x86_64;intel-mkl-core-rt__x86_64;intel-mkl-doc__noarch;intel-mkl-doc-ps__noarch;intel-mkl-gnu__x86_64;intel-mkl-gnu-rt__x86_64;intel-mkl-cluster__x86_64;intel-mkl-cluster-rt__x86_64;intel-mkl-common-ps__noarch;intel-mkl-core-ps__x86_64;intel-mkl-pgi__x86_64;intel-mkl-pgi-rt__x86_64;intel-conda-mkl-linux-64-shadow-package__x86_64;intel-conda-mkl-static-linux-64-shadow-package__x86_64;intel-conda-mkl-devel-linux-64-shadow-package__x86_64;intel-conda-mkl-include-linux-64-shadow-package__x86_64;intel-mkl-common-c__noarch;intel-mkl-core-c__x86_64;intel-mkl-common-c-ps__noarch;intel-mkl-cluster-c__noarch;intel-mkl-tbb__x86_64;intel-mkl-tbb-rt__x86_64;intel-mkl-pgi-c__x86_64;intel-mkl-gnu-c__x86_64;intel-mkl-common-f__noarch;intel-mkl-core-f__x86_64;intel-mkl-cluster-f__noarch;intel-mkl-gnu-f-rt__x86_64;intel-mkl-gnu-f__x86_64;intel-mkl-f95-common__noarch;intel-mkl-f__x86_64;intel-tbb-devel__x86_64;intel-tbb-common__noarch;intel-tbb-doc__noarch;intel-conda-tbb-linux-64-shadow-package__x86_64;intel-conda-tbb-devel-linux-64-shadow-package__x86_64;intel-imb__x86_64;intel-mpi-rt__x86_64;intel-mpi-sdk__x86_64;intel-mpi-doc__x86_64;intel-mpi-samples__x86_64;intel-conda-impi_rt-linux-64-shadow-package__x86_64;intel-conda-impi-devel-linux-64-shadow-package__x86_64;intel-icsxe__noarch;intel-mpi-psxe__x86_64;intel-psxe-common__noarch;intel-psxe-doc__noarch;intel-psxe-common-doc__noarch;intel-icsxe-doc__noarch;intel-psxe-licensing__noarch;intel-psxe-licensing-doc__noarch;intel-icsxe-pset
On a fresh box with no prior installation the input generated previously throws an error.
> sudo ./install.sh -s intel.config
COMPONENTS parameter in silent configuration file contains invalid values
I tried adding double quotes on the COMPONENTS, but that did not help either.
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Can you just run "sudo ./install.sh"?
Yes, the interactive installation works fine. I would like to script this though.
