Will Intel create a single asm instruction packaging all instructions needed to do 3D transformation around XYZ axes ?
An entire 4×4 matrix can be stored inside a 512-bit register, thus a single instruction operating on two 512-bit registers can do the matrix multiplication as:
__m512 _mm512_mul_mat(__m512 MatA, __m512 MatB);
And same goes for the matrix vector multiplication:
__m128 _mm512_mul_matvec(__m512 Mat, __m512 Vec);
I actually do like this:
Thanks for reaching out us.
To my knowledge, there is no inbuilt functionality for matrix multiplication in Intrinsics and I will get back to you after contacting the internal team whether a new feature to be implemented or and if there is an existing function.
Meanwhile could you please try MKL (Intel math kernel library) which supports several math operations and also highly optimized.
To get started with MKL please refer the following article: https://software.intel.com/content/www/us/en/develop/documentation/get-started-with-mkl-for-windows/top.html
Prasanth
Mistake, it's __m128 _mm512_mul_matvec(__m512 Mat, __m128 Vec); instead
Prasanth
3D modeling is more often better performed using Structure of Arrays than using Array of Structures.
struct AoS_t
int N;
Single *X, *Y, *Z, *W; // cache align allocation
bool Alloc(int _N);
AoS_t Bodies;
Then depending on CPU instruction set, The operations (*,/,+,-) are performed on the individual properties of 4, 8 or 16 bodies with each operation. This generally exhibits higher performance when operating on large number of bodies (particles).
Jim Dempsey
I forgot to mention...
In your sample code in post #1 (AoS), you have two horizontal add instructions followed by a scalar store (for a single particle). In the SoA modeling, you would eliminate those two horizontal adds, and follow it with a vector store (for 4, 8 or 16 particles).
Jim Dempsey
As Prasanth mentioned we currently don't have an intrinsic that does what you are looking for. I've opened a feature request with our development team.
My request was not accepted. Thus, we won't have this intrinsic implementation in our compilers.
Thank you for sending us your Feature Request for the Intel Compilers. We have been reviewing older requests such as yours. However, we have decided to close this issue at this time since it is clear that we will not be implementing this particular request in the near future. Your request will be kept on record in our database. We will continue to review this request and all other feature requests each year during planning for the next major release compilers. Your feedback and suggestions are important to us. Thank you for sending us this request to improve our product.
Prasanth
