I have downloaded the trial version of Intel Parallel Composer and installed it on a 64-bit Windows machine.
I've got a C++ project that is using the Intel compiler, and I want to produce a 64-bit executable, but can't see how to.
Hi Jeff,
You have to use the Visual Studio environment to set up C++ project to 64-bit platform as described below.
http://msdn.microsoft.com/en-us/library/9yb4317s.aspx
Reddy
Hi Jeff,
Reddy
Thank you Reddy. That did the trick.
Sorry to be a bit slow replying but life got in the way of good intentions.
Jeff
