I have suceeded in compiling a 64 bit linux kernel with icc 11.0.083 with help from the LinuxDNA project but it gives me a kernel panic when I try to boot it... any help would be most welcome...
PANIC: early exception 06 rip 10:ffffffff8094293b error 0 cr2 f009eb
I know this is an old thread but I thought this would be helpfull and I was unable to find a way to send a pm or email.
Quoting - zhitch
I have suceeded in compiling a 64 bit linux kernel with help from the LinuxDNA project but it gives me a kernel panic when I try to boot it... any help would be most welcome...
I think you might have missed some key steps while installing, configuring and building your Linux kernel.Something which can guide you -
http://www.kernel.org/pub/linux/kernel/people/gregkh/lkn/lkn_pdf/ch04.pdf
Somehow ISN is not a place to discuss issues related with Kernel panic, but probably you can post your issues still to forum like -
http://www.linuxquestions.org
http://www.linuxforums.org/forum/
But still, if you can share the steps incorporated by you to install your Linux kernel, probably suggesting on your kernel panic would be justified.
~BR
Quoting - srimks
~BR
Quoting - zhitch
I am extremely familiar with configuring and compiling a kernel with gcc... I am using icc to compile the kernel with the help of a wrapper but the kernel will not boot. Since I am using the Intel compiler I doubt the links above would have any real useful info. AFAIK noone has compiled a X86_64 kernel with icc before but Feilong H has given some useful info for kernel compiling using icc to the LinuxDNA folks and I figured it might be worth a shot to ask for help here since the kernel compiles and boots fine with gcc, but won't boot with icc. Attached are the wrapper and patches I am using to compile with...
Sorry, I haven't too tried with ICC, maybe some Intel guy can help answering your query.
Since you are working now, the moment it's succesful, please share the procedure done to have succesful kernel built using ICC.
~BR
Quoting - srimks
~BR
Quoting - jumico
