Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
7749 Discussions
( 65536 - 65536 ) / 65536 = -92559592117431994000000000000000000000000000000000000000000000.000000
SergeyKostrov
Valued Contributor II
Please take a look at a Test-Case in DEBUG configuration (!):
printf( ">> Result 1: %f\\n", ( ( 65536 - 65536 ) / 65536 ) * 100.0f );
printf( ">> Result 2: %f\\n", ( ( 65536 - 65536 ) / 65536 ) );
Here are outputs for different C/C++ compilers:
Intel C++ compiler ( Composer XE 2011 Update 9 ):
>> Result 1: 0.000000
>> Result 2: -92559592117431994000000000000000000000000000000000000000000000.000000
Intel C++ compiler command line options:
/c /Od /I "..\\..\\Include" /D "WIN32" /D "_CONSOLE" /D "_DEBUG" /D "_WIN32_ICC"
/D "_VC80_UPGRADE=0x0710" /D "_UNICODE"
/D "UNICODE" /GF /EHsc /RTC1 /MTd /GS /fp:precise /Yu"Stdphf.h" /Fp"Debug\\IccTestAppD.pch" /Fo"Debug/"
/W5 /nologo /ZI /TP /U "_WIN32_MSC" /U "_WIN32CE_MSC" /U"WIN32_PLATFORM_PSPC"
/U"WIN32_PLATFORM_WFSP" /U "WIN32_PLATFORM_WM50" /U "_WIN32_MGW" /U "_WIN32_BCC"
/U "_COS16_TCC" /Qopenmp /Qdiag-disable:111,673
Microsoft C++ compiler:
>> Result 1: 0.000000
>> Result 2: 0.000000
Borland C++ compiler:
>> Result 1: 0.000000
>> Result 2: 0.000000
MinGW C++ compiler:
>> Result 1: 0.000000
>> Result 2: 0.000000
Turbo C++ compiler:
>> Result 1: 0.000000
>> Result 2: 0.000000
Development Environment:
OS: Windows XP 32-bit
IDE: Visual Studio 2005 SP1
Compilers: Intel C++ / Microsoft C++ / Borland C++ / MinGW / Turbo C++
Sergey
Om_S_Intel
I could not reproduce the issue:
c:\forum\U105043>type tst.cpp
// tst.cpp
#include
int main()
printf( ">> Result 1: %f\n", ( ( 65536 - 65536 ) / 65536 ) * 100.0f );
printf( ">> Result 2: %f\n", ( ( 65536 - 65536 ) / 65536 ) );
return 0;
c:\forum\U105043>icl /fp:precise /MTd /Qopenmp tst.cpp
Intel C++ Compiler XE for applications running on IA-32, Version 12.1.1.258 Build 20111011
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
tst.cpp
Microsoft Incremental Linker Version 10.00.40219.01
Copyright (C) Microsoft Corporation. All rights reserved.
-out:tst.exe
-nodefaultlib:libiompprof5mt.lib
-nodefaultlib:libiompprof5md.lib
-defaultlib:libiomp5md.lib
-nodefaultlib:vcomp.lib
-nodefaultlib:vcompd.lib
tst.obj
c:\forum\U105043>tst
>> Result 1: 0.000000
>> Result 2: 0.000000
Is there something I am missing?
SergeyKostrov
You didn't set all my compileroptions.
My Intel C++ Composerversion is:
Intel C++ Composer XE 2011 Update 9, Version 12.1.1109.2005
Did you try the test case inthe Debug and Releaseconfigurations? As I stated in my initial post it happens in a Debug
configuration only.
SergeyKostrov
Pleasetry with these compiler options:
/c /Od/D "WIN32" /D "_CONSOLE" /D "_DEBUG" /D "_VC80_UPGRADE=0x0710" /D "_UNICODE"
/D "UNICODE" /GF /EHsc /RTC1 /MTd /GS /fp:precise /W5 /nologo /ZI /TP/Qopenmp
Sergey
Om_S_Intel
You compiler version string does not seem to be correct.
I am still not able to reproduce the issue.
c:\forum\U105043> icl /Od /D "WIN32" /D "_CONSOLE" /D "_DEBUG" /D "_UNICODE" /D "UNICODE" /GF /EHsc /RTC1 /MTd /GS /fp:precise /W5 /ZI /TP /Qopenmp tst.cpp
tst.cpp
tst.cpp(9): warning #181: argument is incompatible with corresponding format str
ing conversion
-out:tst.exe
-debug
-pdb:tst.pdb
tst.obj
>> Result 1: 0.000000
c:\forum\U105043> cl /Od /D "WIN32" /D "_CONSOLE" /D "_DEBUG" /D "_UNICODE" /D
"UNICODE" /GF /EHsc /RTC1 /MTd /GS /fp:precise /W3 /ZI /TP /openmp tst.cpp
Microsoft 32-bit C/C++ Optimizing Compiler Version 16.00.40219.01 for 80x86
tst.cpp
/out:tst.exe
/debug
tst.obj
>> Result 1: 0.000000
>> Result 2: 0.000000
SergeyKostrov
What exactly do you mean? I don't think that a '...compiler version string...' created that problem.
Sergey
Om_S_Intel
The compiler is rightforthe warning on the following statement :
The Intel compiler generated binary produces the same result as Microsoft compiler generated binary.
SergeyKostrov
Did you try tests in Debug and Release configurations with my compiler options?
I'll try to do another set of tests some time later and will provide more technical details.
Sergey
