I've tried to boil this down to the simplest program I can. This vectorizes with 9.1.051, but reports "routine skipped: no vectorization candidates" with 10.1.18.
[cpp]#includeint main (int argc, char * argv[]) { int count = atoi(argv[1]); if (count <=0) count = 1; float a[count]; float b[count]; float * restrict a_ptr = a; float * restrict b_ptr = b; float * a_stop = a + count; a_ptr[0] = 1.0f; b_ptr[0] = 2.0f; while (a_ptr < a_stop) *a_ptr++ *= *b_ptr++; std::cout << a_ptr[-count] << ";" << b_ptr[-count] << std::endl; return 0; }[/cpp]
using:
/share/apps/intel/cce/9.1.051/bin/icpc -o test test.cpp -O3 -xP -vec-report3 -restrict -std=c99 -ansi-alias
test.cpp(18) : (col. 2) remark: LOOP WAS VECTORIZED.
/share/apps/intel/cce/10.1.018/bin/icpc -o test test.cpp -vec-report3 -ip -restrict -std=c99 -ansi-alias
test.cpp(4): (col. 1) remark: routine skipped: no vectorization candidates.
Any suggestions? Am I missing something obvious?
Eric
The 11.0 compiler, formerly offered at the top of this forum, and still offered at the top of the Fortran and MKL forums, appears to have restored the optimization.
