Intel® C++ Compiler
7838 Discussions
A bug? Undefined reference to 'matmul_mkl_' when -O3 -parallel used in Eclipse CDT
kangshiyin
The following code 'test.cpp' can not be built in eclipse when I add '-O3 -parallel' into build options.
[bash]$ icpc -O3 -parallel -c test.cpp $ icpc -parallel test.o test.o: In function `main': test.cpp:(.text+0x27b): undefined reference to `matmul_mkl_' [/bash]
But it works with the following cmdline:
[bash]$ icpc -O3 -parallel test.cpp [/bash]
And this works too.
[bash]$ icpc -O3 -parallel -c test.cpp $ icpc -O3 -parallel test.o [/bash] I think it's a bug of icc eclipse plugin. Why should it indicate '-O3' when linking, while eclipse plugin doesn't ?
[bash]$ icpc -v icpc version 12.1.3 (gcc version 4.1.2 compatibility) [/bash]
[cpp]#include using namespace std; int main(){ const int n = 500; double(*a) = (double(*))new double[n*n]; double(*b) = (double(*))new double[n*n]; double(*c) = (double(*))new double[n*n]; for (int i = 0; i < n; i++) for (int j = 0; j < n; j++){ a = (double) rand() / RAND_MAX; b = (double) rand() / RAND_MAX; } for (int i = 0; i < n; i++) for (int j = 0; j < n; j++){ c = 0; for (int k = 0; k < n; k++) c += a * b; } double d1 = 0; for (int i = 0; i < n; i++) for (int j = 0; j < n; j++) d1 += c*c; cout << d1 << endl; return 0; } [/cpp]
Miwako_T_Intel
Hi. Thank you very much for a report. We will fix it.
For now, would you please work around by adding "-O3" to linker->miscellaneous->Additional Options?
Miwako
Miwako_T_Intel
Hi.
The fix will be in the next 12.1 update (Update 11 that will come out next month). Thanks.
Miwako
TimP
Black Belt
-O3 -parallel adds (by default) -opt-matmul, requiring linkage against MKL (-mkl for the defaults). This ought to be advantageous, if your matrix is at least 20x20 (otherwise, why are you trying to parallelize?). Maybe the bug fix will be to add -mkl implicitly.
