Hello.This (ICL 12.1.4.325,/Wall):[cpp]template< unsigned threshold > bool fn( unsigned n ) { return n >= threshold; } int main() { fn< 1 >( 123 ); // ok fn< 0 >( 123 ); // warning #186: pointless comparison of unsigned integer with zero return 0; } [/cpp] Is the compiler suggesting that a separate specialization is needed for threshold==0? I think template arguments should be treated more like function arguments with regard to raising this diagnostic message, and less like literals.On another note, I'm still wondering about a minor point from one of my previous posts which was left uncommented probably due to not being stated clear enough. Here, of all the functions, only f1 gets "warning #2536: type qualifiers are meaningless here". It looks like there is some inconsistency regarding this warning.[cpp]#include template< typename ptype > auto f1( ptype ptr ) -> decltype( *ptr ) const { return *ptr; } template< typename ptype > auto f2( ptype ptr ) -> int const { return *ptr; } template< typename ptype > std::remove_pointer< ptype >::type const f3( ptype ptr ) { return *ptr; } template< typename ptype > int const f4( ptype ptr ) { return *ptr; } int const f9( int *ptr ) { return *ptr; } void test() { int x = 123; f1( &x ); f2( &x ); f3( &x ); f4( &x ); f9( &x ); } [/cpp] ----Best regards,Vladimir
http://software.intel.com/en-us/forums/showthread.php?t=105398&o=a&s=lr
There is something wrongwithanalysis of 'unsigned int' variables by Intel C++ compiler in your and my cases.
Sergey
With regards to the second issue (the lack of warning for late specified return types):
(1) On Windows you will see a diagnostic for f4() and f9() if you add the following command line option:
!% icl -c /Qdiag-warning:858 f2.cpp
Intel C++ Compiler XE for applications running on IA-32, Version Mainline Bet
a Build x
Built Jun 9 2012 20:04:48 by jward4 on JWARD4-DESK in D:/workspaces/cfe/dev
Copyright (C) 1985-2012 Intel Corporation. All rights reserved.
f2.cpp
f2.cpp(19): warning #858: type qualifier on return type is meaningless
f2.cpp(23): warning #858: type qualifier on return type is meaningless
f2.cpp(4): warning #2536: type qualifiers are meaningless here
detected during instantiation of "f1" based on template argument
*> at line 29
Diagnostic 858 is only a remark by default on Windows which is why you need to
explicitenable it to see it.We should probably do the same (downgrade the diag to a remark)
with diagnostic 2536 since we have lots of complaints about our Windows compiler issuing more
warnings than Microsoft's. I have entered DPD200232951 for us to do that.
(2) It does look like there is still an inconsistency in that we don't give a diagnostic for f2().
I have entered that into our bug tracking database as DPD200232950. Thank you for reporting it.
thanks,
Judy
Hi to everyone on the thread.
The issue Judy entered about diagnostic 2536 should not be emitted under /Wall is resolved in our Composer XE 2013 compiler. You need to specify /W5 (our Intel compiler-specific highest diagnostic level) to enable it. The other issues/requests are still being worked.
