Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
A simple pipeline parallel problem
chbq
Hi,I have a simple program that calculate the average of the array elements
A=(A[i+1]+A[i-1]+A[j+1]+A[j-1])/2. (0
they have data dependancy so I use pipeline parallel?
I use a array lock as a lock,at first ,initialize all of the data to 0,and initialize the A[0]=1 (,j=0 to N-1); if A[i-1] is calculated ,,the A can calculate at the same time.
however ,I found that theP_Calculation in the following program only work wheniN/2, they do not work.
#include "stdafx.h"
#include "iostream"
#include "vector"
#include "string"
#include "fstream"
#include "iomanip"
#include
#include "omp.h"
using namespace std;
const int N=10;
const string Before="D:\DEMO\Before.txt";
const string SAfter="D:\DEMO\SAfter.txt";
const string PAfter="D:\DEMO\PAfter.txt";
void Init(int nsize,vector &Vec)
int i,j,k;
for(i=0;ifor (j=0;j{
Vec[i*nsize+j]=i*N+j;
// random_shuffle(Vec.begin(),Vec.end());
void OutPut(const string str,int nsize,vector &Vec)
ofstream ofs(str.c_str());
ofs<int i,j,k;
ofs.precision(4);
if((i*nsize+j)%8==0)
ofs<ofs<
void Calculation(int nsize,vector &Vec)
int i,j,first,ix,xi,jy,yj;
for(i=1;ifor (j=1;j{
first=i*nsize+j;//A
ix=(i-1)*nsize+j;//A[i-1]
xi=(i+1)*nsize+j;//A[i+1]
jy=first-1; //A[j-1]
yj=first+1; //A[j+1]
Vec[first]=(Vec[ix]+Vec[xi]+Vec[jy]+Vec[yj])/2.0f;
void P_Calculation(int nsize,vector &Vec,vector &lock)
for(i=0;ifor(j=0;jlock[i*nsize+j]=0;
for(i=0;ilock=1;
#pragma omp parallel for private(i,j,first,ix,xi,jy,yj) default(shared) num_threads(2)
first=i*nsize+j;//A
if(lock[ix]==1) //if the A[i-1] is calculated
lock[first]=1;
int main(int argc, char* argv[])
vector fVec(N*N,0);
vector fVect(N*N,0);
vector mylock(N*N,0);
cout<<"Test is running... "<
Init(N,fVec);
Calculation(N,fVec);
OutPut(SAfter,N,fVec);
Init(N,fVect);
OutPut(Before,N,fVect);
P_Calculation(N,fVect,mylock);
OutPut(PAfter,N,fVect);
cout<<"Test is ended..."<return 0;
if remove the openmp clause,the P_Calculation and the Ca lculation function get the same result. but I do not know why the P_Calculation not work when i>N/2; can you give me some suggestion? thank you !
pbkenned1
The example you posted has numerous syntax errors:
C:>icl -Qopenmp simple.cpp
Intel C++ Compiler for 32-bit applications, Version 8.1 Build 20060606Z Package ID: w_cc_pc_8.1.038
Copyright (C) 1985-2006 Intel Corporation. All rights reserved.
simple.cpp
simple.cpp(19): error: argument list for class template "std::vector" is missing
simple.cpp(22): error: expected a ";"
for(i=0;i for (j=0;j {
simple.cpp(54): error: this pragma must immediately precede a statement
reads(2)
simple.cpp(71): warning #12: parsing restarts here after previous syntax error
simple.cpp(72): error: argument list for class template "std::vector" is missing
simple.cpp(72): error: expected a ")"
simple.cpp(84): warning #12: parsing restarts here after previous syntax error
simple.cpp(84): error: expected a statement
compilation aborted for simple.cpp (code 2)
If you will please file an IntelPremier Support issue, and attach (not copy/paste) a test case that we can compile and run, we will be happy to investigate your issue. Please ask that the issue be directed to Patrick.
Thank you,
Intel Compiler Support
chbq
Thanks for your replying, I have solved this problem ,I synchronize the threadsby the lockfunctions of OpenMP,or define aarray for synchronization.Ican not getthe code of that simple testbecause of my Visual SourceSafe has some problem. I don't know how to attach a file to the forum,so paste the code may result in some problem.
