Intel® C++ Compiler
7956 Discussions
AVX intrinsics with uin8_t and uint32_t
maeshiro_mi
Hi, all. I'm new with intrinsics and your help would be very appreciated.
I want to vectorize some std::vectors processing and my question is, how can I add(or subtract)  std::vector<uint8_t> and std::vector<uint32_t>?
Thanks in advance!
Om_S_Intel
The data types need to be of the same type. Also data access must be done using single stride for vectorization. These condition will not be met in your case.
maeshiro_mi
Thanks om-sachan.
The Auto-Vectorizer is able to vectorize this for loop, right?
std::vector<uint8_t> vec1;
vec1.resize(8192);
std::vector<uint32_t> vec2;
vec2.resize(8192);
for (int i = 0; i < 8192; i++) {
  vec2 += vec1;
So I thought I could code it with intrinsics to start learning.
Thanks again om-sachan!
Bernard
Valued Contributor I
@maeshiro_mi
Run your code and inspect disassembly you should see vmovaps(d) and vaddps(d) instructions or their integer counterparts.
maeshiro_mi
Thanks iliyapolak.
I found very interesting checking assembly and converting it to intrinsics.
Bernard
maeshiro_mi wrote:
Thanks iliyapolak.
I must admit that I am doing the same:)
