Hi Congratulations, now seems it could work correctly without JS I write this thread with using (Links browser) Regards
While the new site looks better the old private threads are inaccessible and they just redirect to http://software.intel.com/en-us/forum.
Let alone that the word verification gets quite annoying...
Hi
The world does not build in one day
he require some time for it work perfectly ...
About Links browser:
Some people could understand that using this Browser is obsolete, but in reality it's an big error.
This browser can work on 2 modes
1] mode text
2] mode graphic. (Quality images are very very well)
The principal interest is the speed that could be is more that *10,20 compared
with the others browser. ( in mode graphic or mode text).
For obtaining this well result you must compile sources with using appropriated
flags possible of your type processor. (Sources link2.7 + dependency)
It's also an well way easy to evaluate compiler optimization with your processor hardware specificity.
ldd links
libtiff.so.5 => /usr/lib/libtiff.so.5 (0x2aac6000)
libjpeg.so.7 => /usr/lib/libjpeg.so.7 (0x2ab25000)
libpng15.so.15 => /usr/lib/libpng15.so.15 (0x2ab6e000)
libX11.so.6 => /usr/lib/libX11.so.6 (0x2ab92000)
liblzma.so.5 => /usr/lib/liblzma.so.5 (0x2ac83000)
libz.so.1 => /lib/libz.so.1 (0x2aca7000)
libdl.so.2 => /lib/libdl.so.2 (0x2acbf000)
libm.so.6 => /lib/libm.so.6 (0x2acca000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x2ad37000)
libc.so.6 => /lib/libc.so.6 (0x2ad49000)
/lib/ld-linux.so.3 (0x54aaa000)
libpthread.so.0 => /lib/libpthread.so.0 (0x2ae33000)
libxcb.so.1 => /usr/lib/libxcb.so.1 (0x2ae4f000)
libXau.so.6 => /usr/lib/libXau.so.6 (0x2ae67000)
libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x2ae72000)
Js not inserted but (meta refresh, mime for link xpdf or evince pdf etc.., openssl for https) working perfectly
./configure --prefix=/usr --with-x --enable-graphics --with-check
before you use make , result configure must show openssl true and all graphic library true.
(except Gpm could be not)
if you use frequently site same Google news or other sites very charged and you are impatient .
this Browser is for you.
I observe also (in trace tcpdump on DMZ) that several links parasites are
ignored ,he will receive not an nails..
(Bad for me Google translator not work ,it's probably my proxy Squid i think)
I forget
you have Also (elinks-0.13-20120819) that could use Js , css,and other option etc ...
but graphic mode is absent..(Browser without the images is same a wife without smile..)
root@bustaf-laptop:/usr/bin# ldd elinks
libX11.so.6 => /usr/lib/libX11.so.6 (0x2aac6000)
libdl.so.2 => /lib/libdl.so.2 (0x2abb7000)
libz.so.1 => /lib/libz.so.1 (0x2abc3000)
libgc.so.1 => /usr/lib/libgc.so.1 (0x2abdb000)
libexpat.so.1 => /lib/libexpat.so.1 (0x2ac11000)
libmozjs185.so.1.0 => /usr/lib/libmozjs185.so.1.0 (0x2ac32000)
libplds4.so => /usr/lib/libplds4.so (0x2aecd000)
libplc4.so => /usr/lib/libplc4.so (0x2aed7000)
libnspr4.so => /usr/lib/libnspr4.so (0x2aee3000)
libiconv.so.2 => /usr/lib/libiconv.so.2 (0x2af0e000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x2afe7000)
libc.so.6 => /lib/libc.so.6 (0x2aff9000)
libxcb.so.1 => /usr/lib/libxcb.so.1 (0x2b0e3000)
libXau.so.6 => /usr/lib/libXau.so.6 (0x2b0fb000)
libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x2b106000)
libpthread.so.0 => /lib/libpthread.so.0 (0x2b113000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x2b12f000)
libm.so.6 => /lib/libm.so.6 (0x2b1dc000)
libmozjs185.so.1.0 (build the lib (nspr) for it added in configure i think required)
I erase it's an doulbe
Hi
New site seem well but it lack an counter visited linked to each threads .
I think is important to evaluate if the subject that you write show an interest or
not.
Other remark:I have not find how to erase thread duplicated ??
About: (Bad for me Google translator not work ,it's probably my proxy Squid i think)
I have compiled the source last squid 3.2.1
Now the utility Google translator work perfectly when
I use the Links browser.
I think with this browser is not *10/20
It's more that * 50 ...
Also this last version Squid seem working more speedily.
Congratulation to this team Squid that offer this
fabulous quality utility, the programming high-level...
Topic Options
