Hello, I have a project that compiles both in Ubuntu and g++ 7.4 and Visual Studio 2019. However, when I use Visual Studio I am stuck with a really old OpenMP version (200203). I am trying the intel c++ compiler to see if using it I can compile the project using a newer version of OpenMP (5.0). My project is CMake-based and I configure it using the following command to compile using intel c++ compiler 19.0 in visual studio:
cmake [Various options to locate all libraries] .. -T "Intel C++ Compiler 19.0"
and then compile using
cmake --build . --config Release
which produces
C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.23.28105\include\pplwin.h(93): error: access violation [PATH TO MY PROJECT] static ::std::shared_ptr<scheduler_interface> * _S_scheduler_address; ^
Any ideas on what might be happening? It's my first time getting an access violation error during compilation.
The same error happens with Debug builds.
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
What version of VS2019 you have? if possible, can you use the older version of VS2019? And also which version of Intel compiler you installed?
When I run the cmake command, the first two lines report:
-- Building for: Visual Studio 16 2019 -- The CXX compiler identification is Intel 19.0.5.20190815
When I open Visual Studio and do Help->About Microsoft Visual Sutido it shows me that it is actually 16.3.2 version. Which older version of Visual Studio do you want me to try?
That version just released 2 days ago which means after Intel compiler 19.0.5 was released. Can you try 16.2.0?
I've downgraded Visual Studio to 16.2.0 (had to remove and reinstall both visual studio and intel parallel studio) and retried compilation with the same result
C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.22.27905\include\pplwin.h(93): error : access violation static ::std::shared_ptr<scheduler_interface> * _S_scheduler_address;
Note that the only difference is with the MSVC folder (previously it was 14.23.28105). Any more ideas?
Can you provide a test case to us to investigate?
