Intel® C++ Compiler
7782 Discussions
Access violation or stack overflow during compilation.
Thierry_D_
I have switched to icc version 16.0.2 (gcc version 5.0.0 compatibility), and now, I cannot compile one of one of my c+++ codes.
Compiler complains:
[100%] Building CXX object CMakeFiles/test3.dir/maintest3.cpp.o
": internal error: ** The compiler has encountered an unexpected problem.
** Segmentation violation signal raised. **
Access violation or stack overflow. Please contact Intel Support for assistance.
compilation aborted for /homes/doua/tdumont/DGSage/Essai/maintest3.cpp (code 4)
So I contact support...
I join a minimal version of the code, suppressing as most lines as possible. Th code is attached. To compile it:
cd BuildIntel
CXX=icc cmake ..
make
With g++-5.1, it compiles perfecly:
cd Build
cmake ..
make
Thany you in advance.
Melanie_B_Intel
Can you show the g++ command line which you use to build the file successfully?
And also the command line for icpc compilation?
Thanks! --Melanie
Melanie_B_Intel
I opened DPD200407975 in our internal bugs database.  Thanks for reporting this problem. -Melanie
